I really don't know how much any of this stuff is worth so I thought I would ask you guys, and I'm trying to sell it so if you want anything just post it or PM me. Thank you
Case: Cooler master 830 stacker
Power Supply: PC Power and Cooling 1200 watt
CPU: AMD Opteron 165 oc'd from 1.8ghz to 3.0ghz
RAM: 1GB (2x512MB) OCZ ram 2-3-2-6 2.65v
Motherboard: Asus A8n-SLI modded to A8n-SLI premiumn
Hard drive: 160GB sata
Optical Drive: Lite-on SATA dvd burner
Video card: Asus 8800 GTS 640
Koolance Water Cooling:
CPU: CPU-330 block
Motherboard: CHC-120-V06
Video card: VID-280 block
MOSFET: vr-as40-v06
Pump: PMP-400 with performance top and t-line
I also have the other longer asus water block if anyone wants it the KOOLANCE VR-AS41, everything is 3/8" fittings except the northbridge cooler its 1/4" So should I be selling this stuff sperate? Or together? How much is it worth? And does anybody want to buy any of it? And it does include the side panel with 4 fans, top fan, back fan, hard drive cage, its just not currently installed, has all front panels just removed them in the picture to show off the pump.
CPU: CPU-330 block
MOSFET: vr-as40-v06
