Alphacool complete liquid cooling system
Pumps and tanks
1x WATER PUMP AND TANK 230V – EHEIM 1001 790
1X WATER PUMP AND TANK POWERED BY THE PSU – EHEIM 1001 760
Hoses – outside 10mm ; inside 8mm
1x 13cm
1x 22cm
1x 38cm
1x 54cm
1x 72cm
3x 145cm – Brand new
Fans – Brand new
3x 12cm Alphacool Black +3x Grill
Radiator
1x Alphacool Nexxxos PRO III 395x120x30mm 600g
1x mounting bracket for the radiator – Brand new
Mountings
1x Socket A – for AMD Athlon XP – Brand new
1x Socket 939 – for AMD X2 – Brand new
2x Socket 775 – for Intel Core 2 Duo and Quad
1x Socket 1366 – for Intel i7
Blocks
1x 4x4x2cm GPU connectors on side
1x 4x4x1,5cm Chipset connectors on top
2x 4,9x4,9x1,7cm CPU connectors on top – one is leaking from cracks but can be fixed
1x NVIDIA 8800GTX SLIM Alphacool GPU
1x NVIDIA 8800GTX Innovatek GPU
1x AMD HD 4890 EK GPU
Joints
12x straight
4x 90degrees
Liquid Coolant
1x 500ml Alphacool coolant
All the screws and washers
For more info, get in touch.
Pumps and tanks
1x 13cm
1x 22cm
1x 38cm
1x 54cm
1x 72cm
Fans – Brand new
Radiator
Mountings
Blocks
Joints
12x straight
4x 90degrees
Liquid Coolant
