HP Pavillion 414uk Problem with CDRW
G
Guest
Guest
Archived from groups: comp.sys.hp.hardware (More info?)
Since yesterday my hp pavilion does not recognise my cdrw. I have tried
looking in device manager and all i get is a yellow circle with a black
exclimation mark against my drive which is a cyberDrv CW088D. I have made
enquiries in another group and have been told that I need to replace my
drive. Can someone more knowledgeable than me please tell me if this is the
case? I should point out that when I look in properties the device status
window displays the following error message:-
Windows successfully loaded the device driver for this hardware but cannot
find the hardware device. (Code 41)
TIA for any help you can give me
G
Guest
Guest
Check the cable and power connections, and examine the motherboard BIOS CMOS
setup information. The CD-RW should show up in the BIOS setup.
.... Ben Myers
On Tue, 14 Sep 2004 14:33:51 GMT, General Martok <Martok@theklingonempire.net>
G
Guest
Guest
> CMOS setup information. The CD-RW should show up in the BIOS setup.
> ... Ben Myers
>>made enquiries in another group and have been told that I need to
>>replace my drive. Can someone more knowledgeable than me please tell me
>>if this is the case? I should point out that when I look in properties
>>the device status window displays the following error message:-
>>cannot find the hardware device. (Code 41)
The problem has now been fixed. It was a problem in the registry.
G
Guest
Guest
On Wed, 15 Sep 2004 10:28:14 GMT, General Martok <Martok@theklingonempire.net>
wrote:
<SNIP>
Unfortunately, a very common occurance with Windows. The Windows registry has
an extremely weak design, prone to errors caused by software manipulating
registry entries incorrectly... Ben Myers
