Archived from groups: alt.internet.wireless (More info?)
Hi,
First thanks for your time.
I've ran out of ideas after 5 days trying to fix this problem. Here is the
scenario:
My network configuration:
Cable modem
|--> Netgear Router/4port switch
|--> 3Com OfficeConnect 11g Access point
|--> Laptop(XP Home) with 3Com 11g Card
Netgear router/switch is the DHCP server and I have set it up to assign
static IPs to my network devices. I have set the 3Com Wireless Access Point
to accept the IP address assigned by Netgear router and I have disabled 3Com
to act as DHCP server. When connected all devices assigned correct IPs and
work fine including my Sony Centring laptop (Xp Pro - 11g built-in card)
without any problem.
However my wife's Toshiba laptop using 3Com 11g Card randomly looses
connection to the internet "Page can not be displayed" and we have to reboot
her PC or unplug/plug the card. When her laptop looses the connection, IP
address is still assigned and wireless signal strength show excellent, but
unable to ping any IPs (LAN or WAN). This problem with her laptop started
happening last week and it has been working fine for over a year.
I have done the followings, but it hasn't fix the problem:
1. Installed latest driver/firmware on Netgear router, 3ComOfficeConnect
Wireless Access point and 3Com 11 g card.
2. Installed Win Xp SP 2 (then uninstalled it as I thought it might have
caused more problems).
3. Disabled WPA, WEP wireless encryption
4. Disabled Sygate software firewall on her PC.
5. Set the IE 6 security to default level and default settings. Also emptied
catch and temp internet files.
6. Changed Wireless channels (but signal strength is not the problem as it
shows "excellent" ).
7. Rebooted all devices after each change.
I think Toshiba software/11g card might be the problem as my Sony laptop
connection to same wireless access point works fine whilst Toshiba laptop
showing the problem.
* When the laptop randomly loses connection, try and see if you can do:
ipconfig /release
ipconfig /renew
This way to see if this laptop can still reach the DHCP Server. This may
tell if the layer 2 data link is still working.
(See if while this has occurred if the other computers can as well release
and renew their IP Address.)
Perhaps this wireless card is going bad? Try a different wireless card and
see if the same problem occurs.
See what is in "arp -a" arp cache:
C:\>arp -a
Interface: 192.168.0.1 --- 0x5
Internet Address Physical Address Type
192.168.0.200 00-0c-41-f3-1f-ed dynamic
* Try to ping again ip addresses of 3Com Access Point, and Netgear Router.
Check arp again (as above). If you don't get a ping response, and you don't
get an arp listing from these devices, then Layer 2 Data Link is not
working. This could be the hardware (wireless card). Try this same thing
with wired network (and other wireless card) both to make sure it isn't
something corrupted in Windows.
Alan Spicer (a_spicer@bellsouth.net)
Systems, Networks, Telecommunications
http://telecom.dyndns.biz
"Mehdi" <nospam@leavemealone.nowhere> wrote in message
news:COV0d.23967$F73.2923@fe2.news.blueyonder.co.uk...
> Hi,
> the
> scenario:
> Cable modem
> Point
> 3Com
> and
> reboot
> emptied
> Sorry for the long post.
> I really appreciate any help or suggestions.
> Kind regards
> Mehdi
Mehdi wrote:
> Hi,
> is the scenario:
> Cable modem
> assign static IPs to my network devices. I have set the 3Com
> Wireless Access Point to accept the IP address assigned by Netgear
> router and I have disabled 3Com to act as DHCP server. When
> connected all devices assigned correct IPs and work fine including my
> Sony Centring laptop (Xp Pro - 11g built-in card) without any problem.
> reboot her PC or unplug/plug the card. When her laptop looses the
> connection, IP address is still assigned and wireless signal strength
> show excellent, but unable to ping any IPs (LAN or WAN). This
> problem with her laptop started happening last week and it has been
> 3ComOfficeConnect Wireless Access point and 3Com 11 g card.
> have caused more problems).
> emptied catch and temp internet files.
> as it shows "excellent" ).
> laptop connection to same wireless access point works fine whilst
> Toshiba laptop showing the problem.
> Kind regards
> Mehdi
"Netgear router/switch is the DHCP server and I have set it up to assign
static IPs to my network devices." Static IP addresses are defined in
the TCP/IP properties for the device. They are not assigned by a DHCP
server. What do you really mean by this? Does each device use automatic
IP address (DHCP) or is the address specificed in the device?
Sigh. How about a clue as to the exact model numbers of your
hardware? I'll assume the Access Point is a model 8250.
Static IP's are a good thing if setup correctly. You can even have
both DHCP and static IP's on the same LAN. However, please do NOT
assign static IP's in the middle of the DHCP address range as you may
end up with a duplicate IP address. Any clues as to how you have the
IP addresses arranged?
Well, I guess your 3com access point is not an 8250, which does not
have a DHCP server. In fact, very few access points have DHCP
servers. What's the 3com model number?
What is "all"?
What model 3Com 11g card?
Yeah, that's a common problem with XP. Go into the advanced
properties for the wireless card and turn *OFF* 802.1x authentication.
If that doesn't do it, disable Wireless Zero Config.
Version numbers of drivers installed? Model number of Netgear router?
There are some rather buggy versions of firmware for various devices.
In some cases, latest may not be best.
Windoze XP SP2 is a great improvement over the previous incantations
in wireless. I've also seen some amazing improvements in wireless
performance after installing XP SP2 (with no clue as to why). I
suggest you first check if your Toshiba laptop requires any updates or
fixes before installing XP SP2, and then re-install it.
I don't think you need a software proxy server behind a Netgear
firewall. If security is the issue, I suggest replacing Sygate with
ZoneAlarm of Kerio personal firewalls (and disabling the Microsoft
firewall that comes with XP SP2).
Yes, I agree that it's probably the Toshiba laptop, XP, or wireless
card. The easiest way to tell is to replace parts and pieces and see
if the problem moves or stays. Therefore, I suggest that you:
1. Go to a wireless hot spot and test the laptop. If that works, you
may have a problem with your unspecified 3com access point.
2. Remove the 3com 802.11g card and try it in a different computah.
If that computah has the same problem, there is something wrong with
the card or the driver.
3. Try a different wireless card in the Toshiba laptop. Cards are
cheap enough that a spare would not be a major expense.
Jeff Liebermann jeffl@comix.santa-cruz.ca.us
150 Felker St #D http://www.LearnByDestroying.com Santa Cruz CA 95060 AE6KS 831-336-2558
Potential XP SP2 network problem fix
hi all, try this; it worked for me. (it's a little advanced, so you
may want a techie friend to help you out. Also, I provide these
instructions as-is and I am not responsible for anything you do to
your computer.. GL!)
DISABLE TCP/IP IN NETWORK CONNECTION
1)Open Network Connections (right click on My Network Places and click
properties)
2)Right click on the offending network connection and click
Properties. (Wireless Network Connection, or Local Area Connection.)
3)Uncheck the checkbox next to Internet Protocol (TCP/IP)
4)Click OK
5)Click Yes if a dialog pops up asking if you want to disable the
other components
Repeat steps 2,3,4,5 for other network connections that are not
working.
RESET WINDOWS TCP/IP
6)Click Start/Run/ type in "cmd" , and click OK
7)in the command prompt, type ipconfig /release
8)type "netsh int ip reset ip-reset-logfile.txt"
This step resets your ip stack in windows.
SEE: Microsoft KB article 299357
»support.microsoft.com/?id=299357
ENABLE TCP/IP IN NETWORK CONNECTION
9)Re-open the 'offending' network connections as outlined in 1),2)
10)Re-Check the checkbox next to Internet Protocol (TCP/IP)
11)Click OK
12)in the command prompt, enter ipconfig /renew
(if you have performed this sequence for a wireless connection, it may
take a moment to re-connect, so you may have to enter ipconfig /renew
a couple of times.
13)check your favorite web browser, you should be all set!
--Abe
"Mehdi" <nospam@leavemealone.nowhere> wrote in message news:<Of31d.33485$v93.7878@fe1.news.blueyonder.co.uk>...
> Thanks for suggestions guys.
> This morning I changed the encryption from WPA to WEP and it seems ok now.
> I have to wait and see.
> Regards
> Mehdi
