I'm using an Antec SL300 power supply for my PC. Checking the voltage of the outputs with a digital multimeter while the system was running (full load with all peripherals connected), I got the following readings:
+3.3V ----------- +3.34V
+5V ------------- +5.05V
-5V ------------- -5.07V
+12V ------------ +12.39V
-12V ------------ -12.88V ***
The voltages are fine except for the -12.88V. Antec specifies that the acceptable range for this is -11.4V to -12.6V. The reading is 0.28V beyond the allowable maximum. My questions are:
1. What exactly is the function of the -12V line?
2. What kind of damage would an out-of-spec -12V line create?
3. Is the excess of 0.28V really something to worry about?
So far my system runs fine without symptoms of any problems caused by a faulty power supply. I'm just afraid that this deviation from normal will slowly erode the reliability of the system and someday take its toll to surprise me with an irrecoverable damage to my motherboard, hard drive or other component.
Thanks in advance for any help or info you could share.
--Michael
--Michael
