I'm dont think this is the best forum for this, but I thought this was the best fit. I have built computers before but this has never happened to me.
Event: I turn on the computer and it'll automatically turns off.
How it all happened. After putting all the components together checking and double checking everything is connected; I turn on the power (stays on for two seconds, nohing on screen) and then it just turns off. I so take off the heatsink, unlock CPU look at (nothing wrong there I hope), lock it down, put the heatsink back on, plug everything back in, and turn on the power. This time I get through the screen telling you whats on the computer and to the DOS looking screen (if fugred great; must have fixed what ever the problems was). So i restart, and go into the BIOS, and start the changing the boot sequence when the computer hangs and turns off again. Now I sit dumbfounded. So I keep trying turn it and the it goes and turns off. Then thought it might be the CPU temp, so after i get into the BIOS it says its only 90F degrees and then turns off. So my next solution was to go down to Frys and pick up a power supply and same new motherboard. Comeback try new items bought and the samething happens. So i figure it might be a faulty case power switch and take back the case and power supply, motherboard to frys. When talking to a person at Frys he told me the porblem might be the RAM, thought about it and said he could be right. So i buy a new case and RAM. Comebck and to no avail the same thing happens again. I am completely lost, getting frustrated, and spending too myuch money on gas for these trips. If anyone could help that would be great.
Here are the components during different attempts:
1st Attempt:
AMD XP 2400+ Plus (2.0GHz)
Thermaltake Volcano 9
MSI K7N2 Delta-L Nforce2 400FSB
2x SAMSUNG 256MB DDR Ram PC2700 333Mhz DDR
W. Digital 120GB (WD1200JB)
Lite-On (LTD-166S) 16x DVD
Lite-On (LTR-52246S) 52x24x52x
SONY 3.5 inch 1.44MB
ATI RADEON 9200 128MB 8X RTL POWER COLOR/DVI/CTR/TV out
Antec Lanboy 350W SmartBlue
Philips 170B2T 17" LCD
2nd attempt:
Switched out power supply and motherboard using same model power supply and same model motherboard.
3rd attempt:
Switched out RAM and Case
Corsair RAM 256MB PC2700
Enermax CS-307 330W power supply
Only during first attempt and 2nd attempt did I get to the BIOS screen. I have even tried just having the CPU and MB powered (no RAM, Video Card, mouse, keyboard), however I still get the same results (turns on and two seconds later it turns off).
1st Attempt:
2nd attempt:
3rd attempt:
