Archived from groups: microsoft.public.windowsxp.newusers (More info?)
I have a new notebook running Windows XP Pro. I have 2 admistrator users on
my system.
After having the computer on (plugged into the wall) for several hours,
sometimes it never goes into screensaver mode. Sometimes it goes into
screensaver and never goes into standby. Sometimes it says "This computer is
in use is in use and is locked" and asks for a password ( I have not set up
user passwords) and when I click OK it says "Insufficient systen resources
to complete the requested service" and freezes.
I cannot easily make it happen because it takes several hours before it
fails.
Please remember some Spy Ware and Ad Aware will load and run in a normal
bootup and you may have to reboot into Safe Mode to run your Spy-Ware and
Ad-Aware to remove them and clean your applications and programs.
Folks who use AOL have a different browswer than everyone else, but they can
use Microsoft Internet Explorer (IE) also.
If they use AOL the right click on photos or links may not work like IE.
Usually IE is in the Programs and you may want to test it.
With IE when the mouse pointer changes to a hand you can click the link or
photo to bring you to another link or page.
If your PC is slowing or hanging up, you may want to run the REAL Spybot &
Ad-Aware where they are at PC Magazine and also here;
"Carol and Allen Bredt" <abredt22@Xsocal.rr.com> wrote in message
news:ePQoe.16495$h86.6758@tornado.socal.rr.com...
>my system.
> is in use is in use and is locked" and asks for a password ( I have not
> set up user passwords) and when I click OK it says "Insufficient systen
> resources to complete the requested service" and freezes.
> fails.
> Can anyone tell me what to do?
> C and A Bredt
> my system.
> fails.
I like using passwords on laptops and other portable systems. They are
already more accessible to unwanted users so why not give them and your
data this little bit of protection?
For the Lock message, go to the Screensaver page in Display Properties and
uncheck the box requiring a password on resume. There is a similar setting
for a password requirement in Power options. Personally, I leave this one
in place but disable the requirement for screensavers.
For the problem of the system not being reliable in using screensavers and
standby, the system is not registering as idle so that these things can
occur. Many possible causes but two very common ones are a running program
that is too aggressive (busy) or one of the drivers is not completely
compatible with standby. Since a driver or program update may be necessary
to fix, would suggest working with tech support for the laptop to determine
the cause.
