Archived from groups: microsoft.public.windowsxp.newusers (
More info?)
Please remember some Spy Ware and Ad Aware will load and run in a normal
bootup and you may have to reboot into Safe Mode to run your Spy-Ware and
Ad-Aware to remove them and clean your applications and programs.
Folks who use AOL have a different browswer than everyone else, but they can
use Microsoft Internet Explorer (IE) also.
If they use AOL the right click on photos or links may not work like IE.
Usually IE is in the Programs and you may want to test it.
With IE when the mouse pointer changes to a hand you can click the link or
photo to bring you to another link or page.
If your PC is slowing or hanging up, you may want to run the REAL Spybot &
Ad-Aware where they are at PC Magazine and also here;
http://download.com
download.com has free downloads (DL) for Spyware and Ad-aware.
Search for and DL at www.download.com to use Spy Bot Search & Destroy.
Search for and DL at www.download.com to use Lavasoft Ad-Aware.
Search for and DL at www.download.com to use The Google Toolbar which stops
Pop-Ups.
Search for and DL at www.download.com to use AVG Anti-Virus if you are not
using McAfee or Norton Anti-Virus.
There are many temp files that increase everytime you use your PC. Have you
deleted the temp files in C:\Windows\Temp\
Or, if you use XP the temp files are under your %user name% similar to;
C:\Documents and Settings\Your Name\Local Settings\Temp
You will find much more info at:
http://www.microsoft.com/athome/security/spyware/spywarewhat.mspx
Regards, Gary 'Doc' Adams in New Orleans @ 314.479.8201
LsuEdu @ msn.com ::
http://digital-mall-online.com
~ Read to Learn - Write to Think ~
"Fatbastard" <cta14427@bigpond.net.au> wrote in message
news:u0J$mFnaFHA.2664@TK2MSFTNGP15.phx.gbl...
> Hi guys and gals , would appreciate any help.
> My PC is only 3 months old and I got a virus in the first few weeks. I
> took it back and they loaded Macafee and said all was fine.
> All but,
> My CD/DVD drive won't read data , dvd or sound cd's.
> It will however read cd's that I burnt , of pictures.
> The sound no longer works either.
> any suggestions?
> I have downloaded many drivers attempting to fix it.
> Cris
