I've just built my first rig using a MSI neo2 FIS2R, when I switched it on it said looking for devices.....none found
then it says
No bios installed. Is that what happens when you first switch a new computer on? It doesn't do a memeory check or show what processor I'm using or anything.
I went into the BIOS setup (del) and it listed all my dirves the CD dive on the primary IDE channel and the HD on the Secondary IDE boot Channel. Also it pick up the floppy drive so I know all the cables in the right place.
Any ideas?
then it says
Any ideas?
