Hi everybody,
I just bought all the components for a new machine, and when trying to install windows I ran into a problem:
I have an Asus A7N8X Deluxe Motherboard and two sticks of 256 MB PC2700 ram. (with a Barton 2500+)
When I boot the computer with the two sticks in ramslots 2 and 3 ( the two blue ones for dual access), the system will not boot properly. Initially all the ram is found, but then it soon crashes, with errors that are apparently memory related (PAGE_FAULT_IN_UNPAGED_AREA, IRQL_NOT_LESS_OR_EQUAL and more). I cannot install Windows.
But when I use EITHER one stick in ramslot 1, it works just fine, and I could install windows without problem.
It also works fine with both sticks in slot 1 and 2, but that won't give me the dual thingy.
Now, does this mean that the ram slot 3 on the motherboard is broken, or could this also have other reasons? (I just want to make sure before I get a new MoBo). It can't be the RAM, right? Or is there something I overlooked that is needed to activate Dual Whatever (I can't manage to remember the proper name)
Thanks in advance,
nagual
Thanks in advance,
nagual
