Archived from groups: microsoft.public.windowsxp.newusers (
More info?)
To select multiple files using the SHIFT key
Press and HOLD the SHIFT key.. select the first file that you want.. while
still pressing and HOLDING the SHIFT key, select the last file that you
want.. ALL files between the first and last will now be highlighted..
If you continue to hold the SHIFT key, the mouse can be used to MOVE the
highlighted selection to another location.. take note of the word 'MOVE'..
Alternatively, after selecting the files using the above method, you can
switch to the CTRL key.. pressing and holding the CTRL key, you can now COPY
the files to another location
OK so far?..
To select multiple files using the CTRL key
Press and HOLD the CTRL.. select the first file that you want.. while still
pressing and HOLDING the CTRL key, select any other files that you want..
they do not have to be consecutive..
If you continue to hold the CTRL key, the mouse can be used to COPY the
highlighted selection to another location.. take note of the word 'COPY'..
after selecting files in this way, you can't then use SHIFT to move them..
they will just be copied..
Good luck
Mike Hall
MVP - Windows Shell/User
"If hard work were such a wonderful thing, surely the rich would have kept
it all to themselves." - Lane Kirkland
"big jim" <jims@nospamisp.com> wrote in message
news:uysti2dcFHA.2420@TK2MSFTNGP15.phx.gbl...
> When I am using the Shift or the ctrl key to select multiple files on the
> desktop that I want to move to another folder they are not allowing me to
> select multiple files only one at a time. What is wrong?
> Jim
