Hello,
I have read the mobo FAQ and tried to find a solution but I still have a dead system.. Nothing is on except the SBPWR led. No lites, no fans, nothing..
Here is what I have done:
1. Verified board correctly mounted into Lian Li case
- no misplaced grounding posts
2. Replaced PSU (old one was probably ok)
3. Checked connections (PSU --> mobo using DVM)
4. Verified the front panel switches working (using DVM)
System:
512Mbyte DDR 433Mhz CORSAIR ram (1 ddr stick)
P4 2.8Ghz 800Mhz bus
fry's floppy disk (generic)
With this I should at least get the system to power up correct? I know it will give errors and such but again I have no power , no panel lites.. only the SBPWR remains on.
System:
