Tom's Hardware > Forum > Games General > Console Gaming > PS3 "Ethernet Cable not connected" problem
Forum Games General : Console Gaming - PS3 "Ethernet Cable not connected" problem
The PS3 keeps showing the fault in the top right corner of the screen "ethernet cable not connected" when the cable is clicked into position in the router and ps3 and the wire has been tested between the router and a computer. The green flashing light flashes for around 3 seconds then will stop for roughtly 3 seconds and then start again. this process is repeated constantly.
The wireless connection works fine but i prefer wired to stop lagging on the online games.
Any information would be helpful?
Sponsored Links
Connection probably isn't configured correctly, which is making it appear to the console like the cable is unplugged.
------------------------------ http://valid.canardpc.com/cache/banner/622598.png
Reply to gamerk316
DHCP problem assigning an IP address to the PS3 by the sound of it - log in to your router and have a check around any wired connection settings to see if there's a problem.
Also check the wired connection settings on your PS3.
Can you connect a PC or other device to the router using teh same cable and ethernet port?
Reply to LePhuronn
There are 1074 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
