CD eject problem
Archived from groups: microsoft.public.windowsxp.newusers (More info?)
I trying to figure out if I have a HW CD manual eject problem. I have a
R50 with a CD-RW/DVD ultra drive unit. Most of the time with a CD in
the drive unit, I can eject the CD with the blue colored button. But I
can not eject the CD when installing a program that asks me to switch a
CD disk. This happens other times also but I can't remember the
situations.
Is there a setting somewhere or do I have a defective drive unit? I
wait until the drive stops on whatever it is doing before depressing the
blue button. I've also tried the Eject from the browser.
Thanks -
2 answers Last reply
More about eject problem
  1. Archived from groups: microsoft.public.windowsxp.newusers (More info?)
    Take a paper clip, straighten it out a bit, and stick one end into the tiny
    hole by the drive itself. It should cause the drive to pop right out. And
    "No," I am not kidding.
    I don't know why they can't make something that ejects when you tell it to!
    But apparently they can't, so the paper clip method can come in handy.
    "Harlen Ng" <harlen@cadence.com> wrote in message
    news:42C81A04.96E062B0@cadence.com...
    > situations.
    > Thanks -
  2. Archived from groups: microsoft.public.windowsxp.newusers (More info?)
    >situations.
    >Thanks -
    The biggest problem [HP] with CD's not ejecting is unreadable sectors.
    The more copy protection they install in software / hardware, the more it
    screws with things that need to use them.
    HW or HP ? I had the same problem with win98. and probably would have had the
    same thing on XP if installing directCD were a possibility on XP. Actually it
    is possible, but you have to say yes to the warnings that tell you not to.
    And recovering from that means a reinstall or possibly a clean tool from HP.
    DirectCD isn't compatible with XP. You should get a hp uninstaller program from
    hp support.
    more pix @ http://members.toast.net/cbminfo/index.html
CD-Rom Windows XP
