I've just bought an MSI 865PE Neo2-S board, with a Geforce FX-5200 T128 AGP card. First, the system booted into windows xp but after installing video drivers I got reboots and all kind of errors.
The videocard is tested in a different system, and is OK.
Now, the system won't even power on, just keeps dead. The only way to boot is with a PCI videocard! (and works perfectly)
Send the board back to my dealer, they have 10 more boards but are unable to get it to work. Swapped DDR, PSU, pulled the board from the case, nothing worked.
Specs:
2x DDR 256 Kingston valueRam 333
MS-8917 Geforce FX-5200 T128 AGP 8x card
500 Watts PSU.
Components checked on Asus P4B533, no probs here.
What can I do?
Thanks, Arthur.
Specs:
500 Watts PSU.
What can I do?
Thanks, Arthur.
