Tom's Hardware > Forum > Games General > PC Gaming > Vista Ultimate 64 issue help
Forum Games General : PC Gaming - Vista Ultimate 64 issue help
I have windows vista 64 bit addition and i keep on having compatibility issues with some programs i keep on getting an error that says the version of the file i am running is not compatible and that i should get a 32 or 64 bit system eve though i already have 64 bit, i don't want to get windows 7 yet and im trying to avoid a reboot. Anybody have any thoughts on how to fix this.
Sponsored Links
Why are you avoiding a reboot?
To be honest, a majority of all Windows related problems are fixed by themselves from simply rebooting.
Reply to TheViper
Are you installing your non-64bit programs to your x86 folder? Be sure to do so when you're using Win Vista 64 as the 32bit emulator will run them in compatibility mode this way!
Rebooting is not something to avoid--although it can be a bit annoying, it is usually necessary.
------------------------------ http://valid.canardpc.com/cache/banner/812049.png
Reply to dirtdiver
I think you should try W7. It is really much better then Vista.
Message edited by ToreTrygg on 11-03-2009 at 02:16:38 PM
Reply to ToreTrygg
There are 995 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 04:06 xyz001 won the Sophmore badge
  • 01:00 scione won the Freshman badge
  • 01:32 aford10 won the Home Brew badge
  • 01:00 Kevinator won the Uniformed badge
  • 01:00 adis won the Uniformed badge
  • 01:00 dabell won the Uniformed badge
  • 01:00 zebo56 won the Uniformed badge
  • 01:00 drkkmittal won the Uniformed badge
  • 01:00 jakesvdyk won the Uniformed badge
  • 01:00 artistjane won the Uniformed badge
