Tom's Hardware > Forum > Games General > PC Gaming > Altered thiefs audio now problems
Forum Games General : PC Gaming - Altered thiefs audio now problems
After successfully installing thief 2 metal ages I then altered the audio it then crashed. I've tried uninstalling it but it won't so I tried manually deleting the file folder then I reinstalled it. but the problem did not change it still won't start. HELP
Sponsored Links
There's a free program called revo uninstaller. Try reinstalling your game, then uninstall using revo, and remove all the registry entries and what not associated with said game, then try to reinstall and see if it can reset it back to original settings and get you running.
Reply to ohiou_grad_06
Tried it didn't work!!
It's so anoying it used to work on vista!!
Reply to scarlatti
There are 632 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 paesan won the Freshman badge
  • 01:00 -pcaddict- won the Freshman badge
  • 01:00 impreza won the Freshman badge
  • 01:00 raulkm won the Uniformed badge
  • 01:00 letus won the Uniformed badge
  • 01:00 pmiddy won the Uniformed badge
  • 01:00 MarcieMark won the Uniformed badge
  • 01:00 kaypeezee won the Uniformed badge
  • 04:06 xyz001 won the Sophmore badge
  • 01:00 scione won the Freshman badge
