Split audio streams on 2 outputs (Standard/HDMI)
Hello,
I have a Radeon HD5850 with a HDMI output that is plugged on my HDTV, I am using Win 7 and the last Catalyst drivers.
The video is working just fine (extended desktop, I can play a movie on the TV while playing a game on my monitor on the other desktop) but I have a problem separating the audio streams.
Is there a way (built in windows, ati driver or external program...) to send the audio stream of some applications (the movie basically) on the HDMI output, and the streams of other applications on my regular audio output at the same time?
Usually on Win7 when you have 2 sound cards you can just set one as default, launch your program, then set the other one as default and launch the other programs and that will do the trick (the streams stay on the output that was the "default output" when they were launched). But with the HDMI of the Radeon, when I switch the default adapter, all the sound is switched...
Do not hesitate to ask if it's confusing. I'll try to explain better.
Thank you!
Nathan
Reply to nbarraille
6 answers Last reply
More about split audio streams outputs standard hdmi
  1. I realize this thread has been dormant since last year. But I have been looking for the exact same bit of information and either can't get the right keyword terms or no one is talking about it.
    Did you find any information Nathan, or can anyone else direct us to some helpful websites?
    In my case, I have a headset I play games with, but my Radeon 5850 would export sounds from a streamed TV show. The computer can handle both, but I can only divert all sounds based on which audio device is set to default.
    Thank you
    Reply to Phaedrus567
  2. Hi,
    No I didn't find any way to do this...
    At that time the Radeon driver did not allow this. Maybe now the newer version offers this, but I doubt it. You can try to ask on the ATI forum.
    As I use XBMC, there is a built-in option to specify the audio output, so I use this.
    Nathan
    Reply to nbarraille
  3. Just go to options in your media player and go devices , go to speaker and choose the ati hdmi output and push ok . close the media player , open a Movie and Done. ps adjust the sound of your TV :P.
    Grtz Smokey
    Reply to Smokey_92
  4. But not every Media Player has options to adjust the output! For example: iTunes and WMP have not such an Option!
    Reply to AC-Suchti
  5. No, with this options you just can see every of your audio devices instead of only one of them! Without enabling this option, you have one audio device which every soudn output signal uses. With this option you can put the different programms on your different Output devices if this programm has such an option.
    Reply to AC-Suchti
  6. nbarraille said:
    Hello,
    Thank you!
    Nathan
    Well, there IS a solution.
    However, be warned, the site that contains the solution doesn't have an http:// or an https:// header before www.example.com
    Here's the site --> http://www.chevolume.com/
    All I can say is that Norton (the chrome extension) only specified it being safe (OK) but there weren't any user ratings or anything.
    ONLY ENTER AT YOUR OWN RISK!
    P.S, I still don't trust it even if it is from France.
    Be very careful.
    Reply to NickThe-TechSavvyFox
Ask a new question Answer
Audio HDMI Windows 7
