sanford
17
Archived from groups: microsoft.public.windowsxp.newusers (More info?)
Win XP Prof SP2; fast user switching turned on; two user accounts.
When I use 'fast user switching' to switch from user 1 to user 2, if,
instead of 'fast switching' back to user 1 (thereby leaving user 2 logged
on), I 'log off' user 2, the monitor screen goes black, all keys go dead,
on-off power switch goes dead. Everything is kaput! The only thing I can
do to get out of this situation then is to unplug the computer and reboot.
Seems that it shouldn't work that way. Am I doing something wrong? Is
there something I don't know? Any help will be eagerly appreciated.
Thanks.
G
Guest
Guest
Did this happen before or after you installed SP2?
I found 2 articles on this subject, one deals with xp Media Center edition,
the other with xp home, pro, and 64-bit editions.
SO, for your xp pro, here is the link to the article, which truthfully is
not all that helpful.
http://support.microsoft.com/default.aspx?scid=kb;en-us;328934
I would first try disabling Fast User Switch, clean temp files, etc, reboot,
then try turning fast user switch on again, and I would turn off the
welcome screen off in Display properties.
Then, if that doesn't work, I would uninstall, then reinstall SP2, first
disabling FUS, then, when SP2 is back, try the FUS again. IF that doesn't
work, then I'd think about the hotfix, but I certainly would not pay a dime
for it.
"Sanford" <sanford@spam.net> wrote in message
news:eI1ntRwkFHA.3960@TK2MSFTNGP12.phx.gbl...
> Thanks.
sanford
17
Thank you, Ivee. That helps. Sanford
"lvee" <notmesothere@msn.com> wrote in message
news:uuW1eq3kFHA.3544@TK2MSFTNGP15.phx.gbl...
> edition, the other with xp home, pro, and 64-bit editions.
> reboot, then try turning fast user switch on again, and I would turn off
> the welcome screen off in Display properties.
> dime for it.
>> can
>> reboot.
>> Thanks.
G
Guest
Guest
Let us know which one solved your problem so that others can try the same
fix. :)
news:gF8Ge.68893$ro.32065@fed1read02...
>> doesn't work, then I'd think about the hotfix, but I certainly would not
>> pay a dime for it.
>>> logged
>>> dead,
>>> can
>>> reboot.
>>> Thanks.
