Archived from groups: microsoft.public.windowsxp.newusers (More info?)
Hi there,
I have been invaded with spyware, and I just want to wipe out the
entire hard drive and start over, I have my store bought copy of
windows XP, I am also connected to the internet via wireless networking
in my home, this computer is not the host. My concern after
reinstalling XP is that I will not know how to reconfigure my Linksys
wireless network. I know I have asked a lot of questions and probably
need to do one thing at a time. I would GREATLTY appreciate it.
It's so much easier to suggest solutions when you don't know too much about
the problem
"maude" <maude.1suqdp@pcbanter.net> wrote in message
news:maude.1suqdp@pcbanter.net...
> Hi there,
> maude
Use the Files and Settings Transfer Wizard to save your settings to a file
on your other computer and then transfer the file back after your
reinstallation of Windows and run the FAST wizard again. I don't think you
will have to reconfigure your wireless network since those settings are
saved in the Linksys router already. All you will need to do is let your
system connect to it. Once you have SP2 reinstalled you should see a
balloon over the TaskBar informing you that a wireless network has been
detected and offering you the opportunity to connect.
> Hi there,
> maude
I don't know if it's possible to just transfer settings, but if possible
just do that. If I were in your shoes however, I would either try to
fix it as it is, or do a complete reinstall (don't use files and
settings wizard).
Don't worry about wiping the drive.. all you need to do is install a
fresh copy of xp/sp2
> file
> you
> are
> your
> been
> "maude" maude.1suqdp@pcbanter.net wrote in message
> news:maude.1suqdp@pcbanter.net...-
> Hi there,
> networking
> probably
> maude-
