L4d2 graphics problems
I get artifacting like this when playing l4d2. I have tried to disable multi-core rendering just incase it might help but most ppl usually do that for a stuttering problem which i have not had. It can happen at anytime sometimes I play for 30 min and no problem sometimes it happens as soon as I load the game. Any suggestions? BTW happens in both Vista 64 and Win7 64. I have an install of each on 2 different HDs.
Here are my PC specs:
AMD Phenom II X4 955 Black Edition Deneb 3.2GHz
Western Digital Caviar Black WD1001FALS 1TB
ASUS Crosshair III Formula
BFG Tech BFGEGTX275896OCXE GeForce GTX 275 896MB 448-bit GDDR3 PCI Express 2.0 x16
Mushkin Enhanced Blackline 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600
Example of what happens: http://img.photobucket.com/albums/v674/Oden02/***.jpg
edit: link doesnt work cuse the file name is filtered..lol $h!t.jpg you get the idea..
Thanks.
3 answers Last reply
More about l4d2 graphics problems
  1. BTW just thought I would add - this is the only source engine game I experience these issues with. I can run pretty much any other game without any graphical issues. However, I did see a similar graphical issue from time to time with batman arkham asylum.
  2. Artifacts may be caused by overheating hardware (GPU/CPU). Can you tell us what kind of temperatures you are hitting at idle and under load for both your CPU and GPU?
    EDIT - I'm assuming you have the latest graphics drivers, yes?
  3. Yes I have the latest (and previous) graphics drivers, chipset drivers etc. I have a scythe Katana III cooler on my cpu and a NZXT Tempest case 3 120mm intake and 3 120mm exhaust fans. under load my CPU core temp is in low to mid 40s and GPU temp mid 50s.
    If it were heat I would assume I would see this issue in more than one game but this is the only game that causes it. I can play every other game without problems. Some examples: Crysis, Batman Arkham Asylum,, HL2 ep1/ep2, TF2, Need for Speed Shift, HAWX, Modern Warfare 2, Red Faction Guerilla etc.
    Also it crops up randomly, sometimes it happens as soon as I enter a game in left 4 dead 2, or sometimes I can play for 30-40 minutes with no problems.
    Honestly its gotten so annoying trying to play l4d2 I'm about to sell this card and pick up an ATI Radeon 5780 or the like.
PC gaming Video Games
