I have an ASUS P4P800 Deluxe motherboard and I have a single WD 120 hard drive connected to the EIDE controller. I've heard that you can connect a single drive up to the RAID controller for better performance. Here are my questions:
Is that true?
If so, how much performance can you expect to get?
Does it have any negative impact on stability?
Do you just plug the ribbon cable into the RAID pin socket?
Thanks.
Is that true?
Thanks.
