inexplicable, fatal computer problem -- HELP!
I've recently been having some serious computer problems, which I'll describe in a moment -- I was told be a computer repair shop that my initial motherboard was shot, so I decided to buy the Asus A7N8X Deluxe. The problems continue!
Basically, the computer will get power -- fans will spin, lights will go on, the floppy drive, cd-rom and hard disk seem to powerup. Sometimes it sits there just like that, and nothing happens -- no pc speaker bleeps out of Post, nothing comes up on the monitor, no hard drive activity ...the computer doesn nothing, gives no errors, doesn't go into BIOS ...it just sits there, with power and with fans spinning, and it does so until I unplug the machine!
SOMETIMES though, it does something -- anything! It varies. It normally just sits there, but sometimes it manages to get somewhere along the way into the boot up process ...It'll freeze at the very first screen, the GeForce screen -- or I'll get that single "all is well" Pc speaker bleep -- I'll get to the Asus screen, or into the XP loading sequence .. BUT It usually it just crashes along the way -- it simply restarts, usually not (but somtimes!) freezing up. Sometimes it even makes it way all the way into XP, working fine until the computer restarts without any warning or error message at all.
Things seem utterly wrong -- the only real "sign" of the computer acknowledging this fact is when the I do get all the way into POST, the Asus board reads my CPU as an Athlon 1500+, when it is actually a 2100+ ...and it says new CPU detected? It freezes there sometime, not allowing the computer to go on ... is this a CPU problem?
I'm really, really lost, and I just put a lot of money into this situation! Can you help me?
As stated, I'm running an Athlon 2100+ XP, on Windows XP, A7N8X Deluxe, with 512 mb of Pc3200 corsair ram. I've got a Geforce Ti4200, though I supsect that has nothing to do with it -- sure, sometimes I get nothing on the monitor, but that's because the pc is not doing anything, I think. And my AGP slot light is not on... which is a good thing.
THINGS WORKED FUN UNTIL OUT OF NOWHERE, which is so perplexing. Then this happened! There was a short out of my Power supply a while back, but I replaced it and figured all was well, and my computer worked fine up until recently -- could some short out from then be finally rearing it's ugly head? If so, why these problems? It seems if any component was failing, except the mobo (which is new), the computer would still at least go into bios, or read some kind of error in post (no hard drive, cpu not correct, no dram, etc...).
Any ideas? This is getting far to expensive to just buy hardware on a hunch - I still supsect my CPU.
PLEASE HELP
Joe Jovanovich
2 answers Last reply
More about inexplicable fatal computer problem help
  1. Sounds like you may have done a number of things. My first guess is the Powersupply. AMD machines are very picky about their power, and if that thing is not rated 350 W or higher, or is a cheap off brand one, it can cause all the problems that you describe. You might also have a power problem with your house, for all machines, I recommend a UPS battery backup system. It also may be your CPU. Take it back to the store that you bough it from and see if they can test it out. AMD processors are very sensitive to heat and phisical abuse, you may have bent a pin, caused electrostatic damage, or other damage while you were installing it, or it may just be a dud.
    If it works for you then don't fix it.
  2. The power supply is brand new -- an Antect TruePower 430, so I'd think that should cover it... but perhaps something is wrong with my elecrcity? My last power supply did short out without warning or purpose! I have always suspected the CPU, but last time they said the cpu was fine -- but perhaps they didn't realy check!?
Motherboards Computer Hard Drives
