Archived from groups: alt.internet.wireless (More info?)
I currently have a Linksys 802-11B router, and am looking to upgrade.
Unfortunately, the product offerings seem to be bifurcating rapidly,
starting to look like the DVD+/-/R/RW/RAM/ROM/CD/CDROM/CDRW confusion..
I'd like to retain compatibility with 802-11b but I'm looking to migrate to
higher speed.
Support is an issue, these days it seems rare to get something that works
properly out of the box.
Linksys has been ok in that regard for me.
I too I'm looking to move on. Linksys was a well supported product until
Cisco moved tech support offshore. I'm looking for wireless network products
(home) with good tech support. I will be replacing 6 Linksys products.
TIA
> to higher speed.
Dave VanHorn thought carefully and wrote on 9/19/2004 8:25 AM:
> confusion..
> migrate to higher speed. Support is an issue, these days it seems
> rare to get something that works properly out of the box. Linksys has
I just upgraded my Linksys "B" home network to Linksys "G with
Speedbooster" this weekend (1 wired, 3 wireless). WRT54GS wireless
router and 2 WMP54GS PCI cards. My daughter's laptop has Atheros 54Mbps
wireless chipset built-in.
I was looking for higher home network speed, good product support, good
experience of other users and increased range and spent a couple months
looking here and there and pondering. (I failed at getting increased
range). I considered Linksys, Netgear products and some high wattage
routers mentioned here. I also considered D-Link, but I can't remember
why I decided to drop them.
The high wattage routers were eliminated because they're 802.11b. I
considered the Netgear WGT634U and WG311T because they're both based on
the same chipset, Netgear was eliminated because I couldn't find any
user experience with the WGT634U and its firmware has been updated 3
times in a few months (that doesn't make me feel good). Netgear was also
offering a $70 rebate at one point, which sort-of makes be wonder if
they're trying to get rid of them.
Linksys won out because of my past and continuing good experience with
their products and email support, good knowledge base, very positive
user experience and 3 year warranty.
My experience with putting together my network is OK. After working well
for about 10 minutes, one of the '54GS PCI cards failed to achieve
speeds above 5.5 Mbps and had a hard time connecting. That card was
exchanged. Now I plan on burning-in the cards. I was disappointed that
the WRT54G(S) doesn't support SNMP logging, but the the firewall enabled
I guess there really isn't any reason for it.
Otherwise, the hardware works exactly as advertised and installed
exactly as expected - I really like that. The router webpage interface
is really nice. My signal strength was not increased, but even the
computer with the troublesome signal strength connects at a minimum of
11 Mbps instead of 1-2 Mbps. My wife's computer connects at 80 Mbps, my
daughter's laptop at it's max capacity of 54 Mbps. When my daughter is
online, network speed does drop to accommodate the non-Speedbooster adapter.
For a short period of time during the network upgrade, I was operating
the PCI cards in "B only" mode for compatibility with my BEFW11S4 router
and the network worked fine. The new router can also be set for G only,
B only, mixed speed and off.
One interesting thing about the 54G and 54GS series - you can get
"customized" firmware written by others. It seems that there are several
features of the chipset that Linksys firmware doesn't take advantage of,
but they've released the firmware source so others can fool around with
it (search for SeavSoft, HyperWRT and others). One feature is the
ability to increase broadcast power - sounds like a potential way to
increase range and burn out your router and I'll be looking into it further.
You left out DL (double layer), FatCD, and Blu-Ray Disk.
http://www.blu-ray.com Everything you own is now obsolete. Product mutation is a way of life
in high tech.
>higher speed.
802.11g is the usual answer. However, you're about to have a
potential problem. 802.11g compatibility requires that 802.11g access
points and client radios slow down to 802.11b speeds in order to
maintain compatibility. The slowdown is mostly in the speed of the
management frames, which switch from the higher 802.11g speeds, to the
ultimate in sludge at 1Mbit/sec, when the 802.11g access point hears
even one 802.11b data frame. The good news is that although
everything slows down, it's still faster than 802.11b. The bad news
is that the typical 20-25Mbits/sec thruput you would get with a short
range all 802.11g system, slows down to about 10Mbits/sec thruput in
the presence of 802.11b radios. That's still faster than the
5-6Mbits/sec thruput you'll get with an all 802.11b system.
Well yeah. You're expected to upgrade the firmware and drivers of
just about anything you buy these days. There is no way that a
manufactory can deliver up to date firmware or drivers out of the box.
Also, if the product were any good, it wouldn't need support. I worry
seriously about the products of a company with fabulous support. If
they needed such a great support organization, what problems are they
trying to solve? Quality issues? Bugs? Incompatibilities? Also,
why am I paying for a fancy support organization to answer YOUR
questions? If I don't have any problems, why should I pay to fix
yours?
For example. Just about every operating system has a method of doing
automatic updates from the internet. Plug it into the a DSL or cable
connection and you're instantly updated to the latest revision.
However, none of the cheap router manufactories[1] seem to have
discovered this simple feature that will drastically reduce their
support load. Methinks they should re-assign the outsourced support
department into fixing the causes of the support calls, and not act as
an expensive band-aid.
Never judge a book or router by its cover. Linksys, Dlink, Netgear,
and others all relabel boards made by contract companies in China,
Taiwan, and Korea. In many cases, the same exact design appears in
competitive products from different vendors. What you should be
looking for is which chipset is best. Atmel, TI, Motorola, Broadcom,
Atheros, and Prism are popular chipset. They can be determined by a
simple web search, or a slog through the FCCID database. Review sites
are also helpful and often discuss internals.
http://tomsnetworking.com http://www.practicallynetworked.com You might wanna dig through the white papers and "need to know" stuff
as it's full of realistic clues.
[1] Sonicwall does online router updates. However, Sonicwall routers
are expensive and they require a support contract.
Jeff Liebermann jeffl@comix.santa-cruz.ca.us
150 Felker St #D http://www.LearnByDestroying.com Santa Cruz CA 95060 AE6KS 831-336-2558
"Suds" <suds@ibm.org> wrote in
news:A4i3d.1886$qA6.1061@newsread3.news.pas.earthlink.net:
> until Cisco moved tech support offshore. I'm looking for wireless
> network products (home) with good tech support.
Everyone is moving offshore... that's a fact of life unless you're willing
to spend more money on hardware.
In article <A4i3d.1886$qA6.1061@newsread3.news.pas.earthlink.net>,
>TIA
Judging by the names, I think it's offshore, but FWIW I actually had
competent technical support through Proxim's website a few months ago.
SonicWall doesn't require a support contract... I'm a reseller and
sell a lot of them but never do I require customers to buy a support
contract.
sj
Jeff Liebermann <jeffl@comix.santa-cruz.ca.us> wrote in message news:<pbkrk0h5foh73ccmq8lvkjcu66gmfte8oe@4ax.com>...
> On Sun, 19 Sep 2004 10:25:37 -0500, "Dave VanHorn"
> http://www.blu-ray.com > Everything you own is now obsolete. Product mutation is a way of life
> in high tech.
> >higher speed.
> yours?
> http://tomsnetworking.com > http://www.practicallynetworked.com > You might wanna dig through the white papers and "need to know" stuff
Although I'm registered with MySonicwall.com for something like 22
assorted routers, Sonicwall refuses to allow me to download updates to
the firmware, VPN software, or anything else useful or important.
Documentation appears to be available. My last call to support to
complain about this specific issue (about a year ago) confirmed that
this is the case. I stopped recommending Sonicwall about that time.
If something has changed, I would be interested as I really like
Sonicwall products. Incidentally, Watchguard has web based firmware
updates, and a similar policy of requireing a support contract.
# Jeff Liebermann 150 Felker St #D Santa Cruz CA 95060
# 831.336.2558 voice http://www.LearnByDestroying.com # jeffl@comix.santa-cruz.ca.us
# 831.421.6491 digital_pager jeffl@cruzio.com AE6KS
My recollection was that they claimed "security" as the reason only certain
people were able to download firmware and client software.
I think we were allowed to have one point of contact for our company.
Clarence A Dold - Hidden Valley (Lake County) CA USA 38.8-122.5
On Thu, 23 Sep 2004 03:23:28 GMT, Jeff Liebermann
>On 22 Sep 2004 19:50:11 -0700, schyler_jones@hotmail.com (Schyler)
>>contract.
>http://www.sonicwall.com/services/download.html
>"Some downloads may require a valid software support contract to be in
>place for the latest version of software to be available."
Ok, I semi-lied. I just logged into MySonicwall.com to check status
and which downloads are available. MySonicwall.com will let me
download firmware for most of the older products on the list.
However, all of firmware for the newer products, demanded that I
"upgrade" my registration to install anything over version 6.5. I
guess(tm) about a year ago is when this change happened as calling
Sonicwall 8x5 support originally yielded a demand for a support
contract.
Back to my original point. It sure is nice to be able to go to a web
page and update the firmware while online. Windoze, Linux, and
MacIntosh can do it. Sonicwall and Watchguard can do it. Why not
Linksys, Dlink, and Netgear?
