Archived from groups: comp.sys.hp.hardware (More info?)
On the seventh day, Rodger Arndt wrote...
> I have a DeskJet 1220C that will not power up. I worked fine one day now
> will not turn on. Does the Power source
> go bad in these? Where do I start.
Plug out the ps, wait a few hours, plug in the ps and check whether it gets
warmer. Should be an indication of operation. Better: Check the outgoing
voltage to see whether it's the ps or the printer itself.
mit freundlichen Grüßen/with kind regards
Christian Dürrhauer, Institute of Geography, FU Berlin
Nostalgia is like a grammar lesson. You find the present tense,
and the past perfect.
I am unsure what you are saying, nothing comes on at all.
how do I get to the ps?
>Plug out the ps, wait a few hours, plug in the ps and >check whether it
>gets
>warmer. Should be an indication of operation. Better: >Check the outgoing
>> I have a DeskJet 1220C that will not power up. I >>worked fine one day
>> now
I've read about this problem in the HP Support forums. Maybe the
following link can give you a hint:
>> gets
>>> now
ps short for power supply. Sorry for being unprecise! :-)
