Hello all, this is my first post here and Im hoping someone can help me...
Here are my specs:
Athlon XP 2400+ Retail
Asus A7N8X Deluxe 400Mhz
512 Corsair TwinxLL
IBM Deskstar 120GB
LiteOn 52x CDRW
Mitsumi Floppy
4x case fans
THermaltake Silentpower 420W
Win2K
I have just switched from retail to the Silent Boost and my system would power up but not go into the boot sequence, it would just stay hanging with a black screen. I disconnected the two case fans I had running directly from the motherboard and the system booted, but stayed hanging on the ASUS splash screen. On the splash screen I pressed tab to go to POST screen and my processor and memory would post, but then it would hang when detecting the IDE drives. I noticed a clanking noise on the hard drive and given the poor reliability record of IBM drives, I surely thought this was the problem. However, I went ahead and disconnected the CDRW which was set as master on the secondary IDE connector on the MB and the system posted and booted up to the OS fine! Now I then left the IDE cable connected to the secondarty connector on the MB and disconnected it from the CDRW itself and it wouldnt work...
Please note that before switching the heatsink, system was running perfectly. Also, I used an antistatic mat and wriststrap when installing the new HS.
Does anybody have an idea of what is going on? Is the IDE controller dead or fried?
Here are my specs:
512 Corsair TwinxLL
IBM Deskstar 120GB
LiteOn 52x CDRW
Mitsumi Floppy
4x case fans
Win2K
