Archived from groups: microsoft.public.windowsxp.newusers (
More info?)
Here you go
http://www.deepburner.com/
http://www.softpedia.com/public/cat/3/1/3-1-13.shtml
http://www.cdburnerxp.se/
You should disable XP's built in burning software before installing third
party software as sometimes they conflict. Right click your CD Writer icon
and select Properties->Recording Tab->uncheck the "Enable..." box
Harry Ohrn MS-MVP [Shell/User]
www.webtree.ca/windowsxp
"sf" <sf@gmail.net> wrote in message
news:ihj5g15lqlp1as2t7qlcg7ritl7h57ot2t@4ax.com...
> On Tue, 16 Aug 2005 07:36:06 -0600, Harry Ohrn wrote:
>> While XP has the ability to copy files to CD you will need third party
>> software to do a CD copy. There are freeware alternatives.
> Can you suggest a couple of the better ones?
> TIA
