Archived from groups: comp.sys.hp.hardware (More info?)
Hi,
Does anyone else have a skew problem with their HP DeskJet? The skew is a
little over 1mm from top to bottom of the left margin on A4. I have tried
all the suggestions on HP's website but nothing fixes the skew. The skew is
visable on the HP skew test page I print.
I originally owned an HP 5650 which worked fine until my wife broke it,
following which I then replaced it with exactly the same model, which I
found had a skew problem. So I returned it to the store, got a new identical
one and had exactly the same skew problem. I retuned that printer too, got
an identical replacement and again had the skew.
I thought, must be the printer model, so I upgraded to a HP 5850, but once
again have the skew.
That makes 4 printers (3 x HP 5650 and 1 x HP 5850) which all skew. (I also
tried an Epson C86, but the ink bled into the 100gsm paper my wife uses and
black text quality was poor).
If anyone has any suggestions, including alternative printers which do not
have a noticable skew it would be much appreciated. Printing is critical to
my wife's home run business making wedding stationery, the skew makes her
products look so poor she can't send them out. She needs a good colour
printer which will not bleed and prints very good quality black text. I am
starting to think a colour laser might be better, but then I see these also
suffer from skew, so am at a loss.
