Archived from groups: microsoft.public.windowsxp.newusers (More info?)
I can't listen to internet radio stations or watch any of the movies on the
news. I downloaded the latest Win Media and nothing works. I've also just
installed a network. Where do I begin to locate the problem? Is it XP, is it
Win Media or is it the network? Everything else in the two computers is
functioning normally.
> the
> just
> is it
> is
> Bob
Try clearing out the cache in Internet Explorer. Just close eveyrthing
and then open up IE. Go to Tools > Internet Options. There should be a
section called Temporary Internet Files. Click Delete Files. Also
delete all the offline files (with a checkbox). Be aware that it can
take some time to delete all the files.
"Evolution54" <Evolution54.1ucwe4@pcbanter.net> wrote in message
news:Evolution54.1ucwe4@pcbanter.net...
>> the
>> just
>> is it
>> is
>> Bob
> Evolution54
I cleaned the cache. It seems that it might be a firewall problem or my XP
security settings that are not letting Media communicate over the internet.
Media will play my CD's and will play some songs on the net but the video
and radio won't work so it appears to be related to streaming. I can't find
a menu in Media for changing any of the settings. I can't even find a help
file in Media. Is there a newsgroup that deals with media? Maybe I'd be
better off installing a different sound application.
Robertm Wrote:
> "Evolution54" Evolution54.1ucwe4@pcbanter.net wrote in message
> news:Evolution54.1ucwe4@pcbanter.net...-
> Robertm Wrote:-
> on
> the
> just
> XP,
> is it
> is
> Bob-
> eveyrthing
> and then open up IE. Go to Tools Internet Options. There should be a
> Evolution54-
> XP
> internet.
> video
> find
> help
> be
> Bob
I just found out that the UDP protocol is required for streaming
contents off the Internet. Try check your firewall and see if it is
blocking the UDP protocol. Also, try another program like winamp and
try see if you can stream off their radio stations. If cannot, then it
should have something to do with the protocol being blocked. Sorry but
I can' seem to find the newsgroup but I am sure someone posted it
before. Try searching for it if this doesn't help.
I found another ng microsoft.public.windowsmedia.player and posted my
problem there. We'll see if anyone there has run into the problem.
Everything works ok on the computer running Win 2000 so maybe Media is not
all that compatible with XP. I tried Winamp and that doesn't work, either,
so maybe it is XP and not Win media player.
Bob
"Evolution54" <Evolution54.1uer1v@pcbanter.net> wrote in message
news:Evolution54.1uer1v@pcbanter.net...
>> Robertm Wrote:-
>> on
>> the
>> just
>> XP,
>> is it
>> is
>> Bob-
>> eveyrthing
>> Evolution54-
>> XP
>> internet.
>> video
>> find
>> help
>> be
>> Bob
> Evolution54
> not
> either,
> Bob
> "Evolution54" Evolution54.1uer1v@pcbanter.net wrote in message
> news:Evolution54.1uer1v@pcbanter.net...-
> Robertm Wrote:-
> Robertm Wrote:-
> on
> the
> just
> XP,
> is it
> is
> Bob-
> eveyrthing
> Evolution54-
> my
> XP
> internet.
> video
> can't
> find
> help
> be
> Bob-
> it
> but
> Evolution54-
Have you tried checking the network tab in the options menu to make
sure all the protocols were checked?
"Evolution54" <Evolution54.1ug51p@pcbanter.net> wrote in message
news:Evolution54.1ug51p@pcbanter.net...
>> not
>> either,
>> Bob
>> Robertm Wrote:-
>> Robertm Wrote:-
>> on
>> the
>> just
>> XP,
>> is it
>> is
>> Bob-
>> eveyrthing
>> Evolution54-
>> my
>> XP
>> internet.
>> video
>> can't
>> find
>> help
>> be
>> Bob-
>> it
>> but
>> Evolution54-
> Evolution54
Where do I find this Options Menu? In Media? In windows? In Internet
Explorer?
It's working, just have to figure out how to use it. To tune in a radio
station I have to go to Google, do a search, then work my way through their
menu and finally play. Next time I start it, I have to go through it all
over again. Seems there must be a way to save a list of favorite radio
stations and access them directly from Media or from some sort of list. They
sure don't tell you anything in the help files. Microsoft says they'll
answer an e-mail for $99 per incident. I could buy as lot of CD's for $99. I
thought this mess was supposed to be plug & play. I can't see many people
having the patience to bother using a computer for listening to the radio.
It's all hype, nothing more than a cruel hoax.
Bob
>> not
>> either,
>> Bob
>> Robertm Wrote:-
>> Robertm Wrote:-
>> on
>> the
>> just
>> XP,
>> is it
>> is
>> Bob-
>> eveyrthing
>> Evolution54-
>> my
>> XP
>> internet.
>> video
>> can't
>> find
>> help
>> be
>> Bob-
>> it
>> but
>> Evolution54-
> Evolution54
> their
> all
> They
> $99. I
> people
> radio.
> Bob
> "Evolution54" Evolution54.1ug51p@pcbanter.net wrote in message
> news:Evolution54.1ug51p@pcbanter.net...-
> Robertm Wrote:-
> my
> is
> not
> either,
> Bob
> Robertm Wrote:-
> Robertm Wrote:-
> on
> the
> just
> XP,
> is it
> is
> Bob-
> eveyrthing
> Evolution54-
> my
> XP
> internet.
> video
> can't
> find
> help
> be
> Bob-
> it
> but
> Evolution54--
> Evolution54-
First of all, since you said its working now, why don't you try open up
Windows Media Player -> View -> Go To -> Radio Stations...
There are tons of radio stations categorized and listening to them is
simple. However, if you want specific radio stations, of course you are
gonna have to search it up. Just find the page, and then bookmark it so
you can go back to it next time. Try see if you can save the link (of
the radio station) onto your desktop so you can have easier access to
it. You can also try the Winamp radio tuner. They also have tons and
tons of music categorized by music type and I am sure what you listen
to is listed there. Hope this helps.
thanks for your assistance through all of this.
Bob
"Evolution54" <Evolution54.1uh2dv@pcbanter.net> wrote in message
news:Evolution54.1uh2dv@pcbanter.net...
>> their
>> all
>> They
>> $99. I
>> people
>> radio.
>> Bob
>> Robertm Wrote:-
>> my
>> is
>> not
>> either,
>> Bob
>> Robertm Wrote:-
>> Robertm Wrote:-
>> on
>> the
>> just
>> XP,
>> is it
>> is
>> Bob-
>> eveyrthing
>> Evolution54-
>> my
>> XP
>> internet.
>> video
>> can't
>> find
>> help
>> be
>> Bob-
>> it
>> but
>> Evolution54--
>> Evolution54-
> Evolution54
> Bob
>>>their
>>>all
>>>They
>>>$99. I
>>>people
>>>radio.
>>>Bob
>>>Robertm Wrote:-
>>>my
>>>is
>>>not
>>>either,
>>>Bob
>>>Robertm Wrote:-
>>>Robertm Wrote:-
>>>on
>>>the
>>>just
>>>XP,
>>>is it
>>>is
>>>Bob-
>>>eveyrthing
>>>Evolution54-
>>>my
>>>XP
>>>internet.
>>>video
>>>can't
>>>find
>>>help
>>>be
>>>Bob-
>>>it
>>>but
>>>Evolution54--
>>>Evolution54-
>>Evolution54
