Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > help! i have xp but my programs run on 98!
Forum Windows XP : Windows XP General Discussion - help! i have xp but my programs run on 98!
Archived from groups: microsoft.public.windowsxp.newusers (More info?)
hi! i just got a used computer as a second PC to use while i'm at uni. some
of the programs i need to use (and have been using on my windows 98 PC) won't
run on the xp os that came w/ the computer i just bought. what can i do?
thanks!
Sponsored Links
Hi
Try using the 'Program Compatibility Wizard'. Failing that you may have to
upgrade those programs to XP compliant ones.
Will Denny
MS MVP Windows Shell/User
Please reply to the News Groups
"ohowlovely" <ohowlovely@discussions.microsoft.com> wrote in message
news:6E70C303-C34E-4023-9B24-75D49C8EFE5E@microsoft.com...
> some
> won't
> thanks!
Reply to Anonymous
>thanks!
What are the names of the programs involved? If you can give us a
list of the program names then there may be others on this newsgroup
who have specific knowledge about that program and can give you
detailed advice.
Many programs do have updates/patches available from the manufacturer
to make them XP compatible. And many others just require a minor
configuration setting change. But most programs designed for Windows
98 work just fine with Windows XP once they are installed (and that is
usually very straight-forward, just the same as it was with Windows
98).
Good luck
Ron Martell Duncan B.C. Canada
Microsoft MVP
On-Line Help Computer Service
http://onlinehelp.bc.ca
In memory of a dear friend Alex Nichol MVP
http://aumha.org/alex.htm
Reply to Anonymous
There are 506 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
