Tom's Hardware > Forum > Windows XP > Windows XP General Discussion > Turning power on to the printer
Archived from groups: microsoft.public.windowsxp.newusers (More info?)
Just got a new computer earlier this week. For almost six years I'd been
using 98SE, along with an HP DeskJet 812C.
The printer's power was always turned on as a result of clicking a Print
icon or command, but now I need to turn on power via the button before
anything will print. Is there some setting that will cause the power to go
on as it did with my prior setup?
Sponsored Links
In news:ulyvXROuFHA.2848@TK2MSFTNGP10.phx.gbl,
Marty <mart915@REEMOOVEfrontiernet.net> had this to say:
My reply is at the bottom of your sent message:
> been using 98SE, along with an HP DeskJet 812C.
> Print icon or command, but now I need to turn on power via the button
> before anything will print. Is there some setting that will cause the
> power to go on as it did with my prior setup?
You might want to look for newer software (not just drivers) for the printer
at the HP site. That MIGHT be your only option as the process for doing so
likely will have changed between 9x and XP. Beyond that, well, updating your
printer to a newer model might also be an idea that you can consider for the
future.
Galen
"You know that a conjurer gets no credit when once he has explained his
trick; and if I show you too much of my method of working, you will
come to the conclusion that I am a very ordinary individual after all."
Sherlock Holmes
Reply to galen
I had the same problem. I had 98SE/W HP 832C. I bought a new computer/W XP
and a HP Officejet and have to turn it off and on at the machine, I really
liked the method of "1 click and print"
"Marty" <mart915@REEMOOVEfrontiernet.net> wrote in message
news:ulyvXROuFHA.2848@TK2MSFTNGP10.phx.gbl...
Reply to Anonymous
I had the same thing happened to me when I changed 98SE/w HP 832C to XP/w HP
Officejet 80xi
Reply to Anonymous
- 0 +
Thank you, I will check the HP site.
"Galen" <galennews@gmail.com> wrote in message
news:%237Xp4$OuFHA.360@TK2MSFTNGP12.phx.gbl...
> printer at the HP site. That MIGHT be your only option as the process for
> doing so likely will have changed between 9x and XP. Beyond that, well,
> updating your printer to a newer model might also be an idea that you can
> consider for the future.
> Galen
> Sherlock Holmes
Reply to Marty
It's a feature of the printer drivers, not XP... so you need to look for
updated drivers from HP. If HP did not include this feature in their newer
drivers, complain to them.
Cari (MS-MVP)
Printing & Imaging
"M Farnam" <mkfarnam@yahoo.com> wrote in message
news:uI0SnTPuFHA.992@TK2MSFTNGP12.phx.gbl...
>HP Officejet 80xi
Reply to Anonymous
Cari (MS-MVP)
Printing & Imaging
news:%23VSEBEPuFHA.2948@TK2MSFTNGP15.phx.gbl...
Reply to Anonymous
There are 974 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
