Tom's Hardware > Forum > Motherboards & Memory > General Motherboard > Jetway 720AF SiS 620 (PII 450) - memory problems
Forum Motherboards & Memory : General Motherboard - Jetway 720AF SiS 620 (PII 450) - memory problems
Anyone heard of problems with installing more than 256Mb SDRAM on these boards? I'm getting intermittant and random system hangs when I try to install 2 x 256 or 1 x 512
Ted
Sponsored Links
it could be that one of the ram sticks are gone or one of the ram slots is gone. if they are not the exact same ram u had originally that may be the problem
<A HREF="http://service.futuremark.com/compare?2k1=6973142" target="_new">3dmark2001</A>
2.4C @ 3.0G
Asus P4C800
Corsair 2x512 3200
Sapphire 9600pro @ 500/700
80G Seagate S-ATA150
Reply to twofruitz
are you installing the ram in the first ram slot? that setup has shared memory for the onboard video and must have ram in slot 1, also the manual doesnt say if it supports single or double sided ram, i have had problems with systems supporting only single sided ram and i tried usiing double sided and got odd results....
Fat, Drunk, and Stupid is no way to go through life Son.
Reply to allanon1965
try updating to a later bios...also what os are you using?
Possibly the 620 may have a 256mb memory limit?
If it isn't a P6 then it isn't a procesor
110% BX fanboy
Reply to pIII_Man
1)installed in DIMM0 (slot 1), and tried the other stick in both the other slots. Still won't accept 512 PC133 in first or any slot.
2) Upgraded BIOS to latest I can find (F10), which helped in that it now accepts 2 x 256 PC100.
3) It won't accept 2 x 256 plus 1 x 128 (or 1 x 64) either
4) Still don't know why it won't accept 1 x 512 PC133 - even the black boot-up screen and BIOS screen is distorted/colour mashed.
I notice that Jeyway released a 720AFrevision2; anyone remember why/whether it's anything to do with this issue?
Ted
Reply to tedeuers
also forgot to mention that the 64Mb single sided works OK and the 128 & 256 double sided works OK.
also the OS is W98SE
Reply to tedeuers
- 0 +
Many motherboards around the time of the PIII 450 had a limit of 256 (double sided) per stick.
The loving are the daring!
Reply to Flinx
There are 771 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
