I purchased a Intel 875 mobo, 3.0 ghz cpu (HT) and 1G PC3200 DDR400 ram, and a new case. After installing everything, and turning on the computer, nothing happens. Fans go on, CD players lights blink (like a normal startup), and then nothing, nothing is displayed on monitor (monitor doesn't even start up, but it works). I was thinking something has to be wrong with either the memory or cpu, or even the mobo. Tried a different video card and still same problem, tried a different case and still same problem. Everything is connected as it should be, according to intels website. Any advice?
Read the first post in this forum!
1.) Make sure your ATX12v (the four pin square header) connection is plugged in
2.) Make sure the board isn't grounded by a misplaced mounting post (aka standoff)
3.) Try starting it without the drives connected anywhere.
If it doesn't work then, you've probably got a bad power supply or a problem with the RAM.
<font color=blue>Only a place as big as the internet could be home to a hero as big as Crashman!</font color=blue>
<font color=red>Only a place as big as the internet could be home to an ego as large as Crashman's!</font color=red>
4.) Make sure your case's power button is connected in the right place
6.) Make sure if your power supply has a cuttoff switch on the back, it's turned on
7.) Make sure your power cord goes to a good power socket.
