I was called out to work on a friends computer. The story she told me was that she had acciently unplugged the computer while it was on. Easy enough, she plugged it back in but the computer wouldn't boot (no case lights, no power supply fan spin). After confirming the power supply was hosed, we got a new. I checked to make sure the new one would work (powered up an old computer with it).
Then I plugged it into the motherboard (connectors the right way, and I had unplugged everything thing else) but as soon as I plugged it into the wall the power supply blew up. Blue flash, loud noise, puff of smoke.
The only two things I can think of is that by some wild chance we got a bad power supply, or that somehow the motherboard is damaged and is killing the power supplies.
Anyone had similar problems? Anyway to check without blowing a third power supply?
The computer is and old Dell PIII 800MHz
and the only info I could find on the mobo is that it is an Intel 815 chipset.
Thank all!
Thank all!
