Recently purchased a custom built pc. The specs are,
Kingston 4GB (2x2GB) DDR3 1333MHz HyperX Memory Kit CL7 1.7V
Samsung HD103SJ Spinpoint F3 1TB Hard Drive SATAII 7200rpm 32MB Cache
AMD Phenom II X4 955 Black Edition 3.2 GHz Socket AM3 8MB Cache
HIS HD 5770 1GB GDDR5 DVI HDMI DisplayPort PCI-E Graphics Card
Samsung SH-S223 22x DVD±RW DL Internal SATA 3 Bezel Drive
Antec 300 Three Hundred Case
Antec TruePower New 650W Modular PSU
I wanted to know if there was any way of getting crysis looking better. At the moment I am running it on high settings, no anti-alising. My frame rate stays at around 40-45. If i crank it up to very high settings then the frame rate seems to suffer abit dropping as low as 25. Can i tweak any settings to boost performance. At the moment I am unfamiliar with over clocking.
I understand crysis is an exceptionally good looking game and high spec pcs are needed to run it at best but mine should be above average?
Thanks alot
Thanks alot
