Tom's Hardware > Forum > Systems > HP > Problem with Proliant dl380
Forum Systems : HP - Problem with Proliant dl380
Archived from groups: comp.sys.hp.hardware (More info?)
Hallo to everyone,
I've a strange problem with dl380 and 36 GB HD SCS3 coming from a 4100 disc
array.
Infact after 2 disc testing, I've a message of imminent failure and
aftersome minutes the HD crashes.
Just because it happenede with 2 discs and on a dl580, Ithink there is
something wrong I do while configuring the disc array.
Unfortunately it is the first time I manage these systems so any suggestion
will be wellcome.
TIA
dex
Sponsored Links
On the seventh day, DexMilano wrote...
> Hallo to everyone,
> array.
> will be wellcome.
Hello, lex,
unfortunately, I'm not lucky enough to afford your server so it's kind of
unfamiliar to me. What I would do if I were you, however, is to check the
hard disks each for itself on a normal host adapter (LSI, Adaptec). Go to
the website of your harddisk manufactorer and get the diagnostic tools.
If all hard disks turn out to be OK you can decide what to test next from
there. HTH
mit freundlichen Grüßen/with kind regards
Christian Dürrhauer, Institute of Geography, FU Berlin
If you find yourself in a hole, the first thing to do is stop
diggin'.
Reply to Anonymous
>> Hallo to everyone,
>> 4100 disc array.
>> is something wrong I do while configuring the disc array.
>> suggestion will be wellcome.
> Hello, lex,
> kind of unfamiliar to me. What I would do if I were you, however, is
> to check the hard disks each for itself on a normal host adapter
> (LSI, Adaptec). Go to the website of your harddisk manufactorer and
> from there. HTH
Thx Christian,
the manufacturer is Compaq.
Using the Array e Disk diagnostic tools in the SmartStart CD, seems
everything is Ok.
Reply to Anonymous
> Thx Christian,
> everything is Ok.
This is not what I meant: Comapq doesn't produce hard disk drives. Take out
each hard disk separately and test it with Hitachi's Drive Fitness Tool
(DFT) on an Adaptec or LSI controller. You can find the DFT on an
easy-to-use Ultimate Boot CD.
HTH
diggin'.
Reply to Anonymous
>> Thx Christian,
>> everything is Ok.
> Take out each hard disk separately and test it with Hitachi's Drive
> Fitness Tool (DFT) on an Adaptec or LSI controller. You can find the
> DFT on an easy-to-use Ultimate Boot CD.
> HTH
Unfortunately no other SCSIequipment available in my company.
dex
Reply to Anonymous
DexMilano wrote:
> Hallo to everyone,
> array.
We have similar hardware but do not experience your problems. However I have to
say disks are not frequently swapped between 4100 and dl380...
Some points to think about:
The 4100 is mistiriously removed from hardware listings and supported hardware
in several os-es and such...
The dl380 comes in several generations now: G1, G2, G3, and G4. As far as I
know, the G2 and the G3 share the same (5i) array. The G4 has a newer build-in
array (6i).
Not all disks suitable for the external raids are suitable for the internal
raids, there are some remarks on using newer disks in older arrays and older
disks in newer arrays.
In the end, if you have HP support, use it. My experience (be it with pa-risc
hardware ;-) is that the drives will be swapped for fresh ones if available.
> will be wellcome.
Check the usability of the disk in the array.
If you have hardware support and/or some warranty left, use it.
CBee
Reply to Anonymous
"CBee" <I.Dont@want.your.spam> wrote in message
news:4199e9a3$0$6367$4d4ebb8e@read.news.nl.uu.net...
> DexMilano wrote:
> > Hallo to everyone,
disc
> > array.
I have just finished installing three DL380G3 systems and each had a note
attached warning that only ultra320 disks would function properly. Check HP
web site to verify specs of your drives.
have to
hardware
I
build-in
> array (6i).
internal
older
pa-risc
available.
suggestion
> > will be wellcome.
> CBee
Reply to Anonymous
There are 1046 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
