Need HELP!
Forum Motherboards & Memory : General Motherboard - Need HELP!
I attempted to install a 160 GB Western Digital HD in my SD11 motherboard and everything went wrong!!
I placed back the old 15 GB drive with the same (I believe) settings as before and the computer gives me an error like this:
type the name of the Command interpreter (E.G.: C;\WINDOWS\COMMAND.COM
What does that mean, and where should I go from there?
Please help.
Thanks in advance
Sponsored Links
It means you messed something up and boot loader can't find command.com
Perhaps your drive is in a different position (D instead of C or something).
<font color=blue>Only a place as big as the internet could be home to a hero as big as Crashman!</font color=blue>
<font color=red>Only a place as big as the internet could be home to an ego as large as Crashman's!</font color=red>
Reply to Crashman
You might need to update the board BIOS so it can read a HD that large ?
Read the BIOS updates available to see if you need them.
Barton 3200+ 400MHz
A7N8X Deluxe
Liquid
2x512 KinstonHyperX PC3200
GeForce FX5900
Maxtor DiamondMaxPlus9@80Gig
SONY CD 52x
SONY RW 52x/24x/52x
SONY DVD 16x/40x
Reply to SoDNighthawk
- 0 +
pop in windows cd and reload Master boot record.. if you messed up command.com.... also is your xp up to date, i know xp won't read larger HD's... i had same problem
Asus A7N8X Deluxe
80gb Maxtor
200gb WD 8mb cache..
Lian-Li PC-60
Lite-On 52X
AMD XP2800+
LeadTek GeForce 4 Ti4200 w/vivo 128mb 8x
Hitachi CML174
1 GB Corsair XMS PC3200 Cas2
Reply to Rob423
- 0 +
Thanks,
as you might imagine I did not answer before because I did not have the computer available. Now, at work, I have some spare time....
I resolved the issue with the new HD by:
1)removing the old
2)reinstalling windows 98
3) formatting with 3 different partitions.
Now I can use it no problem and the size looks around 150 total.
The problem with the old HD still remains.
I will try what rob423 suggested for the Master Boot record.
Thanks everybody,
finally a board with some nice people!
I'll keep you posted on what happened
Reply to joe1
Tom's Hardware > Forum > Motherboards & Memory > General Motherboard > Need HELP!
There are 1278 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
