Archived from groups: alt.internet.wireless (More info?)
Hi All,
Here is my situation;
I'm running a single PC in the house, with no other network devices. I just
switched internet providers to an ADSL company (was on cable before), and
don't have a phone jack in the 'computer room'. To make a long story
short, putting a new jack in the room or wiring into the room isn't an
option. The closest telephone jack is a good 50 feet away.
So I figured that I would go wireless (modem to wireless router to pc via
usb wireless adapter), and started to do a bit of research and only wound
up confusing myself.
Should I go the router and wireless adapter route? If so, what is
generally better; a PCI or USB adapter? I already purchased a SMC
Barricade Router(G) for $69 (which I can still return if need be).
OR
Should I get a Wireless Access point and plug that into the modem? If I do
this, what device should I get for the PC (a usb/pci adapter or another
wap?)
Ideally the solution should be cost effective.
Any and all comments welcome, as I'm eager to learn as much as possible
Thanks,
Mojo
PS: 1 more question, my new ISP provided me with a 'phone line adapter'
which plugs into the telephone jack, and has two outputs. This has me
suspicious - if I plug my adsl in one side and the telephone in the other,
am I hazarding any degredation in performance of the adsl? Would it be a
better idea to just plug the adsl into the wall and say 'bullocks' to using
the splitter? The adapter looks like this...
http://www.bettymills.com/store/im [...] OP9704.JPG
use the router you have already,
buy a usb adapter,
put filters on all phone connected devices except the dsl modem.
Generally I don't like usb adapters here in anything but antenna location is
very important with wireless.
"Mojo" <nospam@nospam.com> wrote in message
news:x5P5d.525938$M95.397661@pd7tw1no...
> Hi All,
just
> OR
do
> wap?)
> Any and all comments welcome, as I'm eager to learn as much as possible >
> Thanks,
> Mojo
using
For a desktop machine I prefer the USB adapter which allows you to more
easily change the direction of the antenna. Otherwise it's sitting down on
the floor behind your desk or wherever.
"bumtracks" <user@unknown.org> wrote in message
news:SPa6d.8742$Cn.7456@trnddc04...
> buy a usb adapter,
> is
>> Hi All,
> just
>> OR
> do
>> wap?)
>> Thanks,
>> Mojo
>> other,
> using
>> http://www.bettymills.com/store/im [...] OP9704.JPG >
