Tom's Hardware > Forum > Motherboards & Memory > General Motherboard > Asus A7N8X Problem w/ Secondary IDE
Forum Motherboards & Memory : General Motherboard - Asus A7N8X Problem w/ Secondary IDE
I turned my computer on today and discovered that it no longer recognized my CD/DVD drives that are on the secondary IDE channel. I switched them and the hdd's that were on the primary channel and the computer then recognized the optical drives but not the hdd's. So it seems that I have a problem with the secondary channel. The only change that I have made in my bios over the last few days is that I disabled my floppy drive (I had to use the cable for something else). I didn't think that it was possible that that could have caused any problem but just in case I reenabled it (nothing happened) and then as a last resort I cleared CMOS (still no devices on secondary channel...) any suggestion? Should I just get a new board??
Thanks
Sponsored Links
Most likely its the cable that connects the optical drive/HDD to the secondary channel on the mobo that needs to be replaced. Swap the cables between Primary and Secondary channels and give it a shot!
<font color=red>
Barton 2500+ @ 10x222 = 2225MHz
A7N8X Dlx Rev 2.0
Kingston Hyper-X 2x256MB DDR500 @ CL2.5-4-3-7
MSI Ti4600 GPU/Memory : 300/660MHz
IBM IDE 80GB + Seagate SATA 2x120GB
</font color=red>
Reply to TheMASK
Nope, it's not the cable (although I was hoping that was the problem) the cable works fine when it's hooked up to the primary channel. I'd rather buy a new cable than a new mobo :(
Reply to Boatis
Not recognized in windows or bios? Try the offending hdd on the primary cable, and see if it is recognized in bios, also enable smartcheck. Could be the hdd has gone south.
Reply to endyen
uh oh... hope his board is still under warranty!
<font color=red>
A7N8X Dlx Rev 2.0
</font color=red>
Reply to TheMASK
There are 1241 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
