Ok, i just built a computer and it was working great. recently the computer crashed and i had to restart. When i did a message appeared saying "monitor in power save mode, activate using PC." Ive tried everything i can to try and fix it but nothing works. here are the things i have tried
1. checking to see if monitor is plugged in all the way
2. checked to see that graphics card was in correctly
3. cleared CMOS
Can you yesy your system with another monitor... I don't think it is a monitor problem.
If another monitor also don't work check if all your hardware is inserted properly and if you can hear your disks boot-up. Does the BIOS give any error beeps by the way?
