having trouble downloading wow patch gets to 10% then stalls
help
Are you trying to do it wirelessly? If you are you could try port forwarding your wireless router. I was having real bad lag problems with WoW with windows 7. I did the windows 7 gaming lag fix {which is easy to do} and I made all of the port exeptions through windows firewall. I still had to port forward my router. I am now running at great latency levels and never leave the green. The wierd thing is that I never had to do this when I was running Vista 32 bit. Just keep in mind that there are a total of 4 ports {I believe} relating to WoW and patch downloads. 2 ports are for actual gameplay, 1 is for voice chat and the other is for patch downloads. The...
help
Are you trying to do it wirelessly? If you are you could try port forwarding your wireless router. I was having real bad lag problems with WoW with windows 7. I did the windows 7 gaming lag fix {which is easy to do} and I made all of the port exeptions through windows firewall. I still had to port forward my router. I am now running at great latency levels and never leave the green. The wierd thing is that I never had to do this when I was running Vista 32 bit. Just keep in mind that there are a total of 4 ports {I believe} relating to WoW and patch downloads. 2 ports are for actual gameplay, 1 is for voice chat and the other is for patch downloads. The ports are available on the WoW website if you need them.
