Tom's Hardware > Forum > Games General > Games General Discussions > Splinter Cell Audio problem
Forum Games General : Games General Discussions - Splinter Cell Audio problem
why is the audio so staticy in SC? it cracks up and is very hard to hear. i have an nforce2 mobo with soundstorm audio, winxp. everything else on my system sounds fine, so it isnt that... are there patches for this? i can barely hear what the guys are saying...
....the crows seemed to be calling him, thought caw....
Sponsored Links
Most likely you have EAX enabled. As far as I know, Soundstorm doesn't support EAX (at least not for me, and I have found no documentation stating otherwise, though it does support EAX2). Go into the game options and disable EAX.
XP 2500+ Barton @ 198x11.5@1.85v
Thermalright SLK-800
Thermaltake Smartfan II
A7N8X Dlx
2x512MB Corsair PC3200
BBA 9700 Pro AIW
2x80GB 7200RPM Maxtor
Soundstorm
Reply to umheint0
Just download the latest drivers for your sound card, I had the same problem
2100 XP Athlon Overclocked (2165Ghz)
1GB DDR Samsung 3200
Geforce 4 Ti 4600 128Mb
2X40Gig Hard Drives,Windows on 1 Linux on the other
17" DVI TFT LG L1710B
Reply to mborrill
I'm having the same problem! I downloaded the latest driver from ASUS, but no luck. I ran windows update and it updated some of my sound drivers, but still no luck. WTF?
Oh yeah, I also downloaded the 1.2b patch from Ubi...
XP1700 TBred-B @ 2.16G (166*13)
Noise Control Silverado HSF
ASUS A7N8X
2x256MB OCZ EL PC3500 DDR
ASUS GeForce3 Ti200
300 Watt PSU
45G IBM 7200
Windows XP Professional<P ID="edit"><FONT SIZE=-1><EM>Edited by kbear2569 on 05/10/03 08:20 PM.</EM></FONT></P>
Reply to kbear2569
Well, it's all better. I checked out Ubi.com and they said to make sure audio virtualization is set to "low" and that you uncheck "3D" and "EAX." Tried it and didn't have any problems after running the game for about an hour.
I hope this is just a software glitch, because one of the reasons I bought the A7N8X deluxe was for the high quality audio!!!
ASUS A7N8X Deluxe
Radeon 9800 Pro
300 Watt PSU
45G IBM 7200
Reply to kbear2569
There are 997 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 Ckaz won the Freshman badge
  • 01:00 james59 won the Uniformed badge
  • 01:00 snarl won the Uniformed badge
  • 01:00 patlabor44 won the Uniformed badge
  • 01:00 Kiren won the Uniformed badge
  • 01:00 WookinPaNub won the Uniformed badge
  • 01:00 kwadams won the Uniformed badge
  • 21:57 brockh won the Sophmore badge
  • 01:00 xpax won the Freshman badge
  • 01:00 Mizoguchi won the Freshman badge
