Asus A7N8X DLX Serial ATA Problem
  • Motherboards
  • NAS / RAID
  • SATA
January 20, 2004 12:52:30 AM
Hi I've been running a Western Digital 120GB IDE drive for a while, recently I bought two 120GB Hitachi Serial ATA drives. I installed them, made sure my SATA jumper (near the CMOS) was enabled. I get the RAID screen and I went into it and it gives me the RAID 0 or 1 options. I don't want RAID, I just want my IDE to be C:, and my two new SATA drives to be E: and F: (or whatever letters). How can I do this? My computer doesn't even see the new SATA drives right now but they are detected during the RAID config.
Asus A7N8X Deluxe v2 -- AMD Athlon XP 2500 Barton Core -- 512 P2700 (duel channel) --
ATI Radeon 9500 -- SB Augidy 2 -- Antec Plus660 AMG 330W case -- XP Pro
More about : asus a7n8x dlx serial ata problem
January 20, 2004 10:48:34 AM
you need to install the sata drivers from the installation cd that came with your mb. shouldn't be any problem to use them the way you've indicated.
January 20, 2004 1:38:36 PM
Agree,i suggest you reinstall the system,and when it show press F6 to install Raid service,insert your CD to setup.Then there shall be no problem.
Truth is somewhere out there!
--Movie 'X Files'
January 20, 2004 4:07:56 PM
You gotta install the silicon raid driver from the CD. If you ever plan on making one of the SATA drives into your prime drive then it maybe a good idea to put those drivers on a floppy.
Barton 2500+ @ 2200mhz (10x220 vcore @ 1.8)
Asus A7N8X Dlx 440 FSB
1gb Geil GD pc3500 Dual Channel (2-3-3-6)
Segata 80gb SATA 8.5ms seek
ATI Radeon 9800 Pro(420/720)
January 20, 2004 4:43:29 PM
I don't think Windows setup will allow use of CD at the F6 prompt. Only the floppy.
January 20, 2004 6:25:25 PM
you are correct.
wpdclan.com cs game server - 69.12.5.119:27015
January 20, 2004 7:18:56 PM
Thanks you everyone for all the help. One thing I don't understand. If I install the SATA drivers, it will install to C: of course which is my primary. I want to take C: out and just use my two SATA drives. So in other words I want to only use my two blank SATA drives and do a fresh install of XP. Then I want to temporarily install my IDE to transfer all my files then rip it back out. So if I only have the two SATA drives installed how can I get SATA0 to be the primary (boot) HD?
