Tom's Hardware > Forum > Motherboards & Memory > General Motherboard > Possible problem with board - please help
Forum Motherboards & Memory : General Motherboard - Possible problem with board - please help
I just recently bought a new 3.0ghz pentium 4 and intel board d865gbf. I installed all my new components in my case and when i turn it on, the machine POSTs, but when attempting to load windows, it completely restarts. This is an unending cycle. Is this a problem with the motherboard settings in the BIOS? Any ideas how to fix this?
Sponsored Links
You might want to list your brand of memory and power supply specs.
Reply to o1die
Just a thought from my own recent experience, do you have BIOS set to boot from your hard drive first or CD-ROM, In the typical BIOS there is an option for the sequence in which the machine looks for the boot files. By default it is ususlly set to a floppy disk first, then the primary (HDD-0) hard drive, and possibly 3rd place is a CD-ROM. I made the mistake of setting to boot from the CD-ROM first when instally Windows XP on a new sytem I built, and after copying some files to the hard drive the installation program will need to reboot, instead of booting from the hard drive to continue running the setup it would boot from the CD-ROM and start back at the beginning of the OS installation process.
Reply to PGH_Bob
LOL, are you using XP or 2k? Are you trying to run a previously installed OS? When you make any major hardware changes you have to reinstall the OS, or it will continuously reboot, especially in the case of XP which is designed to prevent you from making any major system changes after installation.
<font color=blue>Only a place as big as the internet could be home to a hero as big as Crashman!</font color=blue>
<font color=red>Only a place as big as the internet could be home to an ego as large as Crashman's!</font color=red>
Reply to Crashman
There are 1242 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
