shadows16 Distinguished Feb 28, 2010 6 0 18,510 Feb 28, 2010 #1 hello,, i have installed fallout 3 and as i got to the screen that says play and clicked on it, it said that the local component d3dx9_38 could not be found,, i have uninstalled and reinstalled, but it still does not work, can anyone plz help me???
Solution isamuelson Mar 1, 2010 Looks like you don't have the correct video card drivers installed. You need to install the correct video drivers for your video card. A list of system specs would help. What video card are you using and what version of windows are you trying to run it on?
isamuelson Distinguished Aug 1, 2008 1,373 3 19,465 Mar 1, 2010 Solution #2 Looks like you don't have the correct video card drivers installed. You need to install the correct video drivers for your video card. A list of system specs would help. What video card are you using and what version of windows are you trying to run it on? Upvote 0 Downvote Solution
shadows16 Distinguished Feb 28, 2010 6 0 18,510 Mar 11, 2010 #3 thanks, but i found out how to fix it,,,, i just needed to uistall a DLL file Upvote 0 Downvote
shadows16 Distinguished Feb 28, 2010 6 0 18,510 Mar 12, 2010 #4 Best answer selected by shadows16. Upvote 0 Downvote
