Tom's Hardware > Forum > Systems > HP > Help with HP 4P scanner and SCSI card
Forum Systems : HP - Help with HP 4P scanner and SCSI card
Archived from groups: comp.sys.hp.hardware (More info?)
Group:
Can some one tell me what to do keep my old HP 4P flat bed scanner?
This scanner just runs great! As it did the day it was new. It is
hooked to my old P2 866 using a Symbus Logic ISA card .
I have built a new 4P, 1.8,GH, with XP, WOW! God! I love this new
computer, but how do I set up my old flat bed scanner that I want to
keep?
I have no experience with SCSI cards, but I think that I need a PCI
SCSI card to make my scanner go on this new system of mine.
If you can tell me details of what to do and I will need details I
will bless you, owe you, or just be real happy.
Thanks, Bruce Buchanan
brujan(NOSPAM)@the-i.net
Sponsored Links
On the seventh day, Bruce Buchanan wrote...
> Group:
> keep?
Hello, Bruce,
get yourself a NCR810 (now LSI but sometimes also called Symbios Logic) PCI
SCSI controller card with 50 pin external output. Runs great under Windows
XP without additional drivers. You just have to download the ASPI drivers
from LSI (I can send you the link via email) and install the HP DeskScan
software. Works like a charm (if you remove some characters in
c:\windows\system32\config.nt, that is, but I can tell you what to do
there). Such cards usually don't sell for more than a few bucks. they even
cost less on ebay. If you don't have it already, you also need a matching
cable with 50 pin Sub-HD connector and 25 pin Centronics for the scanner.
HTH
mit freundlichen Grüßen/with kind regards
Christian Dürrhauer, Institute of Geography, FU Berlin
Country song: If You Don't Leave Me Alone, I'll Go And Find
Someone Else Who Will
Reply to Anonymous
The other viable option is one of the many Adaptec 2900-series SCSI host
adapters, some with BIOS and some without. But don't get a 2940W, which has a
wide 68-pin external connector on the back.
Some of the Adaptec 2900's have 50-pin miniSCSI external connectors and some
have 25-pin connectors like the Symbios Logic card. I forget which model is
which, except that the 2940 is definitely 50-pin.
Support for Adaptec SCSI is also built into XP... Ben Myers
On 13 Nov 2004 10:19:27 -0800, brujan@electrotex.com (Bruce Buchanan) wrote:
>Group:
>keep?
Reply to Anonymous
- 0 +
Bruce:
If you still have the older 4P
scanner, just order a UPS
to SCSI converter from EBay.
I have the same 4P scanner
and now run it under XP. I
found a converter for $56.00
on EBay.
Jymm
smsdau1@yahoo.com
Reply to Jymm
There are 1027 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
