Hi. I need some help in setting up a new system I am building. I installed the KV8-MAX3, 512 PC3200 RAM, ATI Radeon 9600XT, Athalon 3200+ CPU video, floppy drive and the following motherboards:
Two Seagate Barracuda SATA 160 GB (new) on SATA 3 & 4 on the motherboard
One Seagate IDE Ultra 200 GB(new) as master on IDE 1
One Maxtor IDE 20 GB (old but with my backup files and downloaded drivers) as slave on IDE 1
I need to install Windows XP Professional OS and want to do it on the SATA drives. I want to set a RAID on these two 160 GB HD's, and use the IDE 200 GB HD as a drive for backup.
How do I set up the RAID?
Should I partition the RAID array and install Windows XP on the C drive? If so how large should I make the C drive?
Should I use RAID 0 if I have a 200GB HD for backup? I also have a Sony DVD +/- R/RW, a Plextor CDRW, and an old Plextor SCSI CDRW I plan on setting up as well as installing a Creative Audigy Platinum sound card.
Lastly which is the best order to install drivers to accomplish the above?
Thanks. I would like to do it right the first time. So far the system boots fine with the 4 hard drives, video card, Sony DVD writer and Plextor CDRW
