Cisco 802.11a/b/g Card Problem
Last response: in Wireless Networking
Archived from groups: alt.internet.wireless (More info?)
I have the Cisco 802.11a/b/g Cardbus PC card for my laptop. I cannot get to
the Internet or my network with this card. I can connect to my access point
(Senao NL-3054CB3+), but that is as far as I get. The Cisco desk utility
keeps saying that the card's IP address is 0.0.0.0, no matter if I set the
WAP to visible or invisible. The only place I can manually set the card's IP
is in Windows (running Win2000), but the Cisco utility still sees all zeros
for the IP (and using Windows 2000 alone will not allow me to set the
encryption (unless there is a patch that I'm missing)). I am using WEP 128
bit pre-shared keys, open authentication. I've played with DNS and DHCP on
my router, the WAP, Windows, etc. Brick wall!!
Anyone have any luck with this card? I hope that there is something simple
and stupid that I'm overlooking. I heard that the utility for the Aironet
352 was pretty decent. I'm only running 802.11b, so I don't have a problem
using an older utility as long as it works. Is there a third party utility
that gives you good control over the settings of these triband cards? I
bought this card to give me a little more range over my Orinoco Gold. But
right now, this Cisco is looking like Roy Jones after his last fight!
Any help would be appreciated.
DCWhitty
On Sat, 02 Oct 2004 07:52:38 GMT, "DCWhitty" <dcwhitty@optonline.net>
The above two statements are contradictory. There is no way your
Cisco PCMCIA card can communicate with your access point unless it has
an IP address. It will not work set to 0.0.0.0. Therefore, either
your Cisco desk utility is lying, or you're talking to an alien
invader using a new and wonderful protocol. Since the later is
unlikely, I would suspect that something is causing the Cisco Desk
Utility to not display the IP address.
Visible and invisible refer to broadcasting the SSID. Turn this on
(visible) for now and leave it there. This has nothing to do with the
IP address.
>for the IP
Could I trouble you to see what Windoze 2000 thinks is the IP address?
Open an MSDOS window with:
Start -> Run -> cmd
and inscribe:
ipconfig
It may show multiple network adapters (ethernet, modem, 1394,
wireless). Does the ipconfig show a proper IP address, DNS, and
gateway? It better or you would not be able to talk to your access
point.
No, there's nothing missing assuming you have the right Windoze driver
for the card. It should be in the configuration for the Cisco
wireless card. Maybe you can get to it through a different method.
Start -> Settings -> Control Panel -> Network
Right click on the Cisco Wireless icon and select properties.
There should be something there to specify the encryption. If you're
talking via wireless to the web server inside the Senao access point,
you're done. It's working.
>I am using WEP 128
If you're talking to the web server in the Senao access point via the
wireless link, your done. That part is working.
However, your access point is just a bridge and USUALLY requires a
router to connect to the internet. In this case you have two choices.
1. You can use just the wirless bridge (access point) to connect to
your unspecified DSL or cable modem, and install whatever goofy and
disgusting software is required to connect to the unspecified ISP.
2. Or you can install an ethernet router between the DSL or cable
modem and the access point, and have it deal with the ISP.
The problem with #1 is that the access point configuration utility may
have an IP address that is radically different from the IP assigned by
the ISP. You may be able to connect to one, or the other, but not
both, depending upon your configuration.
Luck is helpful, but not required. Expertise is usually more useful.
Use the utility that came with the card. It's not working (0.0.0.0)
so the real question is why.
Does your Orinoco Gold card work?
For that matter, does a direct connection to whatever you have the
access point connected to also work?
What other hardware (DSL/cable modem, router) have you not mentioned?
>DCWhitty
Jeff Liebermann jeffl@comix.santa-cruz.ca.us
150 Felker St #D http://www.LearnByDestroying.com
Santa Cruz CA 95060 AE6KS 831-336-2558
It appears that DHCP is having a difficult time assigning an IP address.
One of the things you can try is manually assigning the IP address. You
may have already done so but, in case you haven't, disable DHCP in the
router's config. menu. Disable encryption until we get your situation
taken care of. If there's a STATUS section, jot down the DNS numbers.
Save the settings then exit the router's menu. Go to your Windows
Control panel/Network Connections then right click on your wireless
network connection. Click on PROPERTIES and then highlight INTERNET
PROTOCOL (TCP/IP). Click on the properties tab and then click on OBTAIN
AN IP ADDRESS AUTOMATICALLY. Fill in the blanks. For now, make sure your
settings are in line with that of the IP address of your router. For
example, if your router's IP address (also known as the gateway address)
is 192.168.0.1 then manually assign your wireless device to be
192.168.0.2. Once you get it working correctly, I suggest you change
these numbers. My router allows me to change all of the numbers while
other only allow you to change the last two sections of the IP address.
Anyway, click APPLY and see whether or not you can successfully surf the
net. If this doesn't work, we'll try something else. Chat with you
later.
"DCWhitty" <dcwhitty@optonline.net> wrote in
news:a7t7d.22559$kq6.13392580@news4.srv.hcvlny.cv.net:
> get to
> point (Senao NL-3054CB3+), but that is as far as I get. The Cisco desk
> utility keeps saying that the card's IP address is 0.0.0.0, no matter
> if I set the WAP to visible or invisible. The only place I can
> manually set the card's IP is in Windows (running Win2000), but the
> Cisco utility still sees all zeros for the IP (and using Windows 2000
> alone will not allow me to set the encryption (unless there is a patch
> that I'm missing)). I am using WEP 128 bit pre-shared keys, open
> authentication. I've played with DNS and DHCP on my router, the WAP,
> simple and stupid that I'm overlooking. I heard that the utility for
> the Aironet 352 was pretty decent. I'm only running 802.11b, so I
> don't have a problem using an older utility as long as it works. Is
> there a third party utility that gives you good control over the
> settings of these triband cards? I bought this card to give me a
> little more range over my Orinoco Gold. But right now, this Cisco is
> DCWhitty
"Doug Jamal" <bishiv6ERASEATYAHOODOTCOM@yahoo.com> wrote in message
news:Xns957664EEDA49ERASEbishiv6atyahood@65.32.5.122...
> later.
Thanks Doug!
Seems to be an encryption problem bet. the Senao AP and the Cisco. 128-bit
WEP didn't work. Disabled WEP, and everything worked. Switched to WPA
passphrase, and got connected immediately (static IPs, gateway, DNS server
info., Internet and network access, etc.). But the signal with WPA is good,
but not great. So I'll have to try another form of encryption (i.e. 40-bit
WEP, or 802.1x, or WPA with a different cypher strength) to see if that
improves the signal.
Let's cross the fingers . . . .
Related ressources
"Jeff Liebermann" <jeffl@comix.santa-cruz.ca.us> wrote in message
news:n3ktl0pp87trm69aqldjeqmon9gg0r474g@4ax.com...
to
point
Jeff, problem seems to have been the encryption (see my last post). Dropping
128-bit WEP solved the problem.
snip
Like I said. Encryption. Everything was working fine until I added the Senao
and the Cisco to the system. The Senao replaced an SMC2655W access point
(which was working fine at 128-bit WEP), and the Cisco replaced the Orinoco
(which was also working fine at 128-bit WEP). The Senao even worked somewhat
with the Orinoco at 128-bit WEP (I could get Internet access, but no
connection to the rest of my PCs on the network), but didn't work at all
with the Cisco at 128-bit WEP.
The Senao and Cisco now work well using WPA passphrase, although the signal
is not stellar in a corner of the house where I will be using the wireless
laptops the most (BTW: I am in the process of following your advice in
another thread re: "throwing the cable out of the window" LOL and trying to
run some outdoor-rated Belden Cat5E into my basement, in order to relocate
the access point to a lower floor).
So which form of encryption gives the best mix of speed and security,
because I'd like to find a happy medium (before I throw the cable out of the
window LOL!). Is it 40-bit WEP, 128-bit WEP, 802.1x, WPA w/TKIP or WEP
cypher, etc.
Thanks.
On Sat, 02 Oct 2004 19:09:02 GMT, "DCWhitty" <dcwhitty@optonline.net>
Sorry. I thought that your statement:
"I can connect to my access point (Senao NL-3054CB3+), but
that is as far as I get."
mean't that you can connect from the Cisco card to the Senao access
point web browser. You would need to have an IP addresa and working
encryption to do that. Next time, please be a bit more specific.
I've observed many WLAN's where DHCP works with no encryption and
fails erratically when encryption is enabled. I just dealt with a
Dlink DWL-624 and D-Link DWL-G510 network with exactly the same
problem. Just to make it weirder, there were three machines with
DWL-G510 PCI wireless cards. Two ran older software, while one was
updated to the latest. The older ones would work most of the time,
while the new drivers required much thrashing with ipconfig and
enable/disable to get an IP address.
I'm not sure exactly what's causing the problem. I plan to do some
sniffing and capture some packets for analysis. My guess(tm) is that
it's mostly the access point, because all three computahs would
associate and get DHCP addresses from a Netgear WRG614 I happen to
drag along (troublehshooting by substitution).
>laptops the most
Huh? The Cisco 352 and Senao cards are among the "high power" flavour
with 100mw and 100/200mw power output respectively. They also have
considerably better receivers than average. If anything, you should
have noticed an improvement over the previous SMC box. Something is
wrong in the RF part of the puzzle.
Chuckle. Whatever works. I just wished they made CAT5E cable with a
translucent jacket so it would be less visible. I have a bright blue
cable temporarily installed (about 2 years now) out the window of my
office, and a big hunk of bright yellow ethernet coax (RG-8/u) to an
antenna. Overly conspicuous would be an understatement.
Hmmm... They have transparent satellite dishes:
http://www.plasteurope.com/new_products/detail.asp?tid=...
why not transparent cable?
The best. Dump wireless and use CAT5. Nothing less than a wiretap
will break in.
>cypher, etc.
I prefer WPA-PSK (pre-shared key). Not perfect but good enough.
Actually, I prefer unencrypted and use SSH and VPN tunnels for
everything. However, that's a bit awkward for most users.
"DCWhitty" <dcwhitty@optonline.net> wrote in message
news:i1D7d.25259$kq6.15124840@news4.srv.hcvlny.cv.net...
>> > get
> to
> point
>> an IP address.
The OP probably meant that the laptop _associated_ with the AP. This is a
problem with Open authentication. It lures you into believing that your
connection with the AP is fully operational, when you've associated, but you
haven't got the encryption straightened out.
> Senao
> Orinoco
> somewhat
> signal
> is not stellar
Encryption has nothing to do with signal strength. Signal strength is a
factor (along with receiver sensitivity, noise, multipath reflections, and
modulation scheme) in receiving the transmitted bits and interpreting them
to match what was sent. Once the bits of the ciphertext are received, they
can be decrypted into plaintext.
> the
> cypher, etc.
Speed and security are pretty much opposing forces. WPA is stronger than
WEP 128/104, which is stronger than WEP 64/40. I wouldn't be too concerned
about the speed differences, but the stronger encryptions will be slower.
Ron Bandes, CCNP, CTT+
news:fv3ul0119s0n565t328qgks17ora6avor6@4ax.com...
Dropping
Well, you know what I meant!!! (I did say that the Cisco utility kept
reading "0.0.0.0" no matter what I fiddled with). I set static IPs, default
gateways, disabled DHCP on the router, the AP and in Windows (turned off the
DHCP client service), and the utility still kept showing zeros. Once the WEP
encryption was dropped (and the WPA encryption used), the utility properly
showed the IP I assigned to the card. Funny, the utility lets you do pretty
much everything else except set the meaningful IP/gateway/DHCP stuff. No one
wants you to use the Windows configuration utilities, but these product
manufacturers don't leave you any choice.
Senao
Orinoco
somewhat
SNIP
signal
wireless
> >laptops the most
Huh? That's exactly what I said. I thought the so-called high powered
Senao/Cisco combo would have sent my signal
into my neighbor's kitchen, but it seems to have only landed in my cat's
litter box! I have everything set to 802.11b, so that signalling and range
shouldn't be a problem. The only true benefit of these multiband APs and
adapters are the new technology encryption protocols. For pure range and
ease of use, I prefer the pure 802.11b stuff anyday. I personally think the
Cisco's not doing the job, b/c the Senao does improve the range somewhat
with the Orinoco (I plan on sending the Cisco back to the guy I bought it
from for poor packaging, but that's another story). I ordered an SMC 2532W-B
long range card (same specs as the Senao 2511CD 802.11b cards), and will see
if there's an improvement.
> will break in.
the
> >cypher, etc.
If my project of "throwing the cable out of the window" is successful, I
will be relocating the AP to the same room where the laptops will be used
(the entire first floor is open space). So signals and range won't be an
issue anymore, even with industrial-strength encryption.
On Sat, 02 Oct 2004 09:28:16 -0700, Jeff Liebermann
What?!? Before you tell someone they don't know what they are talking about, you
should know what you are talking about.
How do you think you get an IP in the first place?
1. You connect to the AP
2. Your machine sends out a DHCPDiscover packet asking if any machine can give
it an ip address
3. A DHCP Server (or multiple servers) replies with a DHCPOffer packet
4. Your machine chooses one, and replies with a DHCPRequest packet. It includes
its MAC address is this packet along with an IP # preference (if so configured)
5. The DHCP Server replies with a DHCPACK packet, informing your machine of its
IP address, and how many seconds the lease is good for
At no time during this entire exchange does your machine have to have a valid IP
address for any of the communications to take place. Some clients default to
0.0.0.0, others (MS) default to a different value. It doesn't matter, since it
all takes place via broadcast packets.
OK, now I'm guilty of not being very clear. I assumed that he was
able to connect to the access point and tweak the built in web server
values to enable/disable/set encryption settings and such, which were
later discussed. You can't do that without a valid IP address.
However, after DHCP has delivered an IP address, such things are
possible. My statements were based on his statemen:
(Senao NL-3054CB3+), but that is as far as I get."
which to me means that everything is working to the access point and
that the failure was an inability to deliver an IP address. I
appologize for the misinterpretation and assumption. I seem to have a
different definition of "connect" than most people. To me, it means
"it works and I can talk to it".
Since most access points do not have a built in DHCP server, and there
was no mention of where the DHCP server was located (router, ISP,
Linux server, Windoze server, etc), my comments were an attempt
determine what was happening. The details and solution were clarified
in later postings, but there was no way to tell if there was even a
DHCP serve available in the original posting.
Incidentally, MS only defaults to 169.254.xxx.xxx until AFTER a DHCP
broadcast fails to get a reply. During the exchange, the IP address
can be literally anything, but is usually 0.0.0.0. In Windoze XP, the
default IP address can be set to something other than 169.254.xxx.xxx.
I do this when dealing with a system that chronically fails to deliver
an IP address via DHCP and I have to default it to a static IP
address, DNS, and gateway.
Ask the community
