Problem Description: When computer is turned off for any short period (1 min or so) of time, and I go to start it, hit the Power On case button on my case, the computer sounds like it is starting, but nothing comes on the screen. I hit the Reset Switch on my Case and the setup begins(screen shows BIOS int), as it should have when I hit the case Power On switch, BUT when my O/S comes up it comes up in a Microsoft WIndows ME Setup Mode, and indicates that ME had been previous shut down abnormally. It also wants to go to a sleep mode, but I select the Normal mode, from the ME Setup menu and it gets me into my ME O/S main menu and All's Well again. I can work with my applications normally, and can shut down normally, via the Start, Shut down selection, and ME shuts down correctly. Also, If I hit the Power On case button within 30 seconds, the system starts normally, but if I leave the system shut down for more than 30 seconds, the problem mention above reoccurs. This one has me stumpted :<, any suggestions ???
