I just recently purchased a new Zenith mobo with the 875P chipset. I am having a hard time trying to adjust the memory timings in the BIOS. It seems the board will not allow me to do it at all. I am using some inexpensive Mushkin value type RAM (2x 256 PC-3200 in dual channel mode)that seemed to work great in a P4C800 Deluxe I was using. With the ASUS board I was able to adjust the timings with no problem, but not the Zenith board, it wont even post if I try to lower the CAS latency to 2. Has anyone had any luck or experience with this board. No type of overclocking is stable as the system wants to lock up and act stupid. BF Vietnam runs like crap now with frequent lagging (no such problems with the ASUS). The only reason the ASUS is not being used is that it needs to be RMA'd due to a faulty chipset. Even my AquaMark 03 benchmarks are jumpy on the Zenith (at a high of 42,000 to a low of 36,000) Below are my system specs. If anyone feels that the memory is holding me back what would be the best RAM for me to be looking into?
Chaintech Zenith CT-9CJS (latest BIOS revision 11-17-2003)
P4 3.0C
2x Mushkin Enhanced (Basic Green) 256 PC-3200 in dual channel
Generic 350 watt PSU
Sony DVD burner DRU-510
1x WD800 HD (no RAID)
1x WD400 HD (no RAID)
ATI 9700 Pro
Onboard Envy 24 sound enabled
Onboard LAN (the Intel one) being used as this board has 2 to choose from
P4 3.0C
ATI 9700 Pro
